jQuery UI Widgets Forums Grid tooltip styling for a grid column
This topic contains 12 replies, has 4 voices, and was last updated by  Dimitar 11 years, 2 months ago.
  • tooltip styling for a grid column #49268
    mallepaddi
    Hi
    Is there a way changing style of grid tool tip for a column from standard to custom ?
    tooltip styling for a grid column #49292
    Hi mallepaddi,
    The tooltips used in the Grid are set through the “title” attribute i.e the Style depends only on the browser. Unfortunately, we are not aware whether the browser’s titles can be styled.
    tooltip styling for a grid column #49301
    mallepaddi
    HI
    that’s fine, but please help how do we show custom tooltip for a column in Grid, rather then showing value “title” attribute.
    tooltip styling for a grid column #49303
    Hello mallepaddi,
    Here is some input from me – there is a workaround on the matter, which you can find in the forum topic Grid tooltip (the last example on the page).
    tooltip styling for a grid column #49337
    mallepaddi
    HI
    cellhover: function (element, pageX, pageY)
    // update tooltip.
    $(“#jqxgrid”).jqxTooltip({ content: element.innerHTML });
    // open tooltip.
    $(“#jqxgrid”).jqxTooltip(‘open’, pageX + 15, pageY + 15);
    from above code .. how do i get actual content of “cell”, i need to edit for showing it as a tooltip and any idea on applying styling and need to show tool tip on certain conditions ?
    and “cellhover” is a function of JQWIDGETS ? i don;t find any documentation related to this?
    tooltip styling for a grid column #49354
    Hi mallepaddi,
    In the following snippet is shown how to get the displayed cell value (cellValue) and style it (tooltipContent):
    cellhover: function (element, pageX, pageY) {
        // update tooltip.
        var cellValue = $(element.innerHTML).text();
        var tooltipContent = "<div style='color: Green;'>" + cellValue + "</div>";
        $("#jqxgrid").jqxTooltip({ content: tooltipContent });
        // open tooltip.
        $("#jqxgrid").jqxTooltip('open', pageX + 15, pageY + 15);
    You can put the jqxTooltip content setting and open method call in an if statement to show the tooltip conditionally.
    The cellhover callback function is jqxGrid-specific. We will include it in the API Documentation as soon as possible.
    tooltip styling for a grid column #49363
    mallepaddi
    Hi
    Great help ..
    Custom tooltip working .. but need further help on showing tool tip conditionally, help me how to code it.
    Here is the scenario :
    – We have quantity field displaying in grid (input editor)
    – some times quantity field turns to red color if the quantity entered is exceeding available quantity, this column is not displaying in grid but part of var dataFields = [ … ]
    Now i need to show conditional tool tip only for quantity fields which are in red color (entered qty > available qty) .. tip should be like “Quantity entered exceeded”
    how to use “open” call to do this ?
    tooltip styling for a grid column #49469
    mallepaddi
    HI
    Any help ?
    tooltip styling for a grid column #49476
    dana
    I am trying to solve this same exact problem. Where does the “cellhover” method belong so that I can use it?
    tooltip styling for a grid column #49495
    mallepaddi
    HI
    Thanks for helping ..
    $(“#jqxgrid”).jqxGrid(
    width: 670,
    selectionMode: ‘singlecell’,
    // trigger cell hover.
    // update tooltip.
    // open tooltip.
    { text: ‘Name’, dataField: ‘firstname’, width: 100 },
    { text: ‘Last Name’, dataField: ‘lastname’, width: 100 },
    { text: ‘Product’, editable: false, dataField: ‘productname’, width: 180 },
    { text: ‘Quantity’, dataField: ‘quantity’, width: 80, cellsalign: ‘right’ },
    { text: ‘Unit Price’, dataField: ‘price’, width: 90, cellsalign: ‘right’, cellsformat: ‘c2’ },
    { text: ‘Total’, dataField: ‘total’, cellsalign: ‘right’, minwidth: 100, cellsformat: ‘c2’ }
    tooltip styling for a grid column #49520
    Hello dana and mallepaddi,
    Here is an example, based on the demo Default Functionality.
        <script type="text/javascript" src="../../jqwidgets/jqxtooltip.js"></script>
                var url = "../sampledata/products.xml";
                var productNameUpdate = false;
                    datatype: "xml",
                        { name: 'ProductName', type: 'string' },
                        { name: 'QuantityPerUnit', type: 'int' },
                        { name: 'UnitPrice', type: 'float' },
                        { name: 'UnitsInStock', type: 'float' },
                        { name: 'Discontinued', type: 'bool' }
                    root: "Products",
                    record: "Product",
                    url: url,
                        if (productNameUpdate == true) {
                            commit(true);
                    if (value < 20) {
                        return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; color: #ff0000;">' + value + '</span>';
                    else {
                var availableQuantity = 20;
                // initialize jqxGrid
                $("#jqxgrid").jqxGrid(
                    width: 670,
                    altrows: true,
                    enabletooltips: true,
                        var cell = $('#jqxgrid').jqxGrid('getcellatposition', pageX, pageY);
                        if (cell.column == "QuantityPerUnit") {
                            // update tooltip.
                            var cellValue = cell.value;
                            if (cellValue > availableQuantity) {
                                var tooltipContent = "<div style='color: Red;'>Quantity entered exceeded</div>";
                                // open tooltip.
                            } else {
                                $("#jqxgrid").jqxTooltip('close');
                      { text: 'Product Name', columngroup: 'ProductDetails', datafield: 'ProductName', width: 250 },
                      { text: 'Quantity per Unit', columngroup: 'ProductDetails', datafield: 'QuantityPerUnit', cellsalign: 'right', align: 'right', width: 120 },
                      { text: 'Unit Price', columngroup: 'ProductDetails', datafield: 'UnitPrice', align: 'right', cellsalign: 'right', cellsformat: 'c2', width: 100 },
                      { text: 'Units In Stock', datafield: 'UnitsInStock', cellsalign: 'right', cellsrenderer: cellsrenderer, width: 100 },
                      { text: 'Discontinued', columntype: 'checkbox', datafield: 'Discontinued' }
                    columngroups: [
                        { text: 'Product Details', align: 'center', name: 'ProductDetails' }
                    var column = args.datafield;
                    if (column == "ProductName") {
                        productNameUpdate = true;
                    } else {
            <div id="jqxgrid">
    Note that when available quantity is loaded from the data source, the if clause should be as follows:
    if (cellValue > dataAdapter.records[cell.row].availableQuantity) {
    where availableQuantity is your available quantity datafield.
    tooltip styling for a grid column #49529
    mallepaddi
    Hi
    fantastic,
    but could you please know where we can documentation on available properties / methods available for following :
    cell, event, element, row etc.
    I haven’t found under documentation section, documenting those would help many of us.
    tooltip styling for a grid column #49596
    Hi mallepaddi,
    We will add the cellhover callback function to the documentation as soon as possible. As for event, each event argument is specified in the event’s entry in the API Documentation.
