jQuery UI Widgets › Forums › Grid › help in adding delete button and selectring row
This topic contains 3 replies, has 2 voices, and was last updated by ivailo 9 years, 8 months ago.
hello,i need a help in adding the delete button to my grid.i am just a newbee in jquery so forgive me if i had made a mistake.i have added the code from above solution,i could get a column named ‘delete’ but cant find the button in the column for delete.also each time i click the rows to select it,only one row is selected and even when i click other rows only the first selected row remains selected. thanks in advance.
My code:
<!DOCTYPE html> <html lang=”en”> <head> <!– The jQuery library is a prerequisite for all jqSuite products –> <script type=”text/ecmascript” src=”jquery-1.11.0.min.js”></script> <!– This is the Javascript file of jqGrid –> <script type=”text/ecmascript” src=”jquery.jqGrid.min.js”></script> <!– This is the localization file of the grid controlling messages, labels, etc. <!– We support more than 40 localizations –> <script type=”text/ecmascript” src=”grid.locale-en.js”></script> <script type=”text/javascript” src=”jqxbuttons.js”></script> <script type=”text/javascript” src=”jqxgrid.pager.js”></script> <script type=”text/javascript” src=”jqxgrid.selection.js”></script> <!– A link to a jQuery UI ThemeRoller theme, more than 22 built-in and many more custom –> <link rel=”stylesheet” type=”text/css” media=”screen” href=”jquery-ui.css” /> <!– The link to the CSS that the grid needs –> <link rel=”stylesheet” type=”text/css” media=”screen” href=”ui.jqgrid.css” /> <link rel=”stylesheet” type=”text/css” media=”screen” href=”ui.jqgrid-bootstrap-ui.css” /> <link rel=”stylesheet” type=”text/css” media=”screen” href=”ui.jqgrid-bootstrap.css” /> <meta charset=”utf-8″ /> <title>jqGrid Loading Data – JSON</title> </head> <body> <div class=”container-fluid”> <div class=”row well”> <h3 class=”heading” style=”margin-left:10px;”>Dashboard</h3> <br> <br> <table id=”application-list” style=”"> <script type=”text/javascript”> var applicationGrid = $(“#application-list”), myData = []; applicationGrid.jqGrid({ datatype: “local”, data: myData, colNames: ['id', 'Product', 'qty', 'free','Delete'], colModel: [ { name: 'id', hidden: true }, { name: 'Product', width: 750 }, { name: 'Qty', width: 200 ,align: 'center' }, { name: 'Free', width: 200, align: 'center' }, { text: 'Delete', datafield: 'Delete', columntype: 'button', cellsrenderer: function () { return "Delete row"; }, buttonclick: function (row) { // open the popup window when the user clicks a button. id = $("#jqxgrid").jqxGrid('getrowid', row); var offset = $("#jqxgrid").offset(); $("#popupWindow").jqxWindow({ position: { x: parseInt(offset.left) + 60, y: parseInt(offset.top) + 60} }); // show the popup window. $("#popupWindow").jqxWindow('show'); } }, ], rowNum: 10, rowList: [5, 10, 20], pager: ‘#application-list-pager’, gridview: true, rownumbers: true, autoencode: true, ignoreCase: true, sortname: ‘created_at’, viewrecords: true, sortorder: ‘desc’, autowidth: true, height: ‘auto’, caption: ‘Ordered Products’, }); $(“#popupWindow”).jqxWindow({ width: 250, resizable: false, theme: theme, isModal: true, autoOpen: false, cancelButton: $(“#Cancel”), modalOpacity: 0.01 }); $(“#del”).jqxButton({ theme: theme }); $(“#cancel”).jqxButton({ theme: theme }); $(“#del”).click(function () { $(‘#jqxgrid’).jqxGrid(‘deleterow’, id); $(“#popupWindow”).jqxWindow(‘hide’); }); $(“#cancel”).click(function () { $(“#popupWindow”).jqxWindow(‘hide’); }); $(window).on(“resize”, function () { var newWidth = $(“#application-list”).closest(“.ui-jqgrid”).parent().width(); applicationGrid.jqGrid(“setGridWidth”, newWidth, true); }); function addRow(){ jQuery(“#application-list”).addRowData(“3″, {id:”0″,Product: $(“#Pro”).val(),Qty:$(“#qty”).val(),Free:”0″}); } </script> </table> <div id=”application-list-pager”> </div> <br> </div> </div> <div style=”display: inline-block;”> Product : <input type=”text” id=”Pro” size=”35%” > Qty : <input type=”text” id=”qty” size =”15%”> <input type=”submit” id =”btn” onclick=”addRow()” value=”Add” > </div> </body> </html>
Hi mailstoakhil,
We recommend usage of jqwidgets about all needed elements.
Ivailo IvanovjQWidgets Team
http://www.jqwidgets.comHI Ivailo Ivanov,I didnt understand what u told.Can you provide me with a solution in my code?
Hi mailstoakhil,
You uses jqgrid. Instead you can use jqxGrid.
Usage of widgets, that are part of the same framework means better compatibility and avoid a lot of problems.If you want to integrate our widgets this article will be helpful for you.
