jQuery UI Widgets Forums General Discussions General Mobile Widgets Question
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 10 years, 9 months ago.
  • General Mobile Widgets Question #57336
    markus_ja
    when I want to use your widgets for mobile devices, what is mandatory to prepare? In the mobile demos, there are 2 div tags:
    <div id=”demoContainer” class=”device-mobile-tablet”>
    <div id=”container” class=”device-mobile-tablet-container”>
    What are they used to do? Do I need them?
    Do I need to manually configure the class “device-mobile” or “device-mobile-tablet”?
    General Mobile Widgets Question #57337
    Hi markus_ja,
    You don’t need to do anything. The mobile demos define these DIV tags for the purposes of the demo which is to display the widget within a container and to show that the widget can be set up to fit to a given size using percentage width and height values.
