jQuery UI Widgets Forums Grid z-index issue with jqxGrid cell in jquery dialog
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 10 years, 6 months ago.
  • harsh
    I am opening jqxGrid (with editing mode) in jquery dialog.
    Problem: it’s not allowing to edit a cell.
    After investigating I found that ‘div[role=”gridcell”]’ has the inline z-index which is lower than ‘input [editing]’s.
    If I increase the z-index of ‘div[role=”gridcell”] then it’s working fine. But Here I need to use ‘!important’ which I don’t want.
    Is there any option to set explicit z-index rather than allowing it at runtime (inline)? Also please share other solution if there is any.
    Thanks in advance!
    Harshal
    Hi Harshal,
    The editor is inside the cell so this is not related to z-index because the editor is a child of the cell. I don’t suggest you to modify any z-index set by jqxGrid. Your problem is probably related to the Dialog’s z-index and I suggest you to use higher z-index for your dialog or simply use jqxWindow instead.
