jQuery UI Widgets Forums Dialogs and Notifications Window Window focus setting
This topic contains 5 replies, has 2 voices, and was last updated by  Dimitar 11 years, 11 months ago.
  • Window focus setting #17214
    Ivalde
    Within my site I have a window with an OK button.
    When the window is opened, I would like it to be focused so that the user can close it directly with either the Esc key or the Enter key (ie. simulating OK button click). For the standard JQuery dialog box this is built-in standard mechanismes. So how to make it work for your jqxWindow?
    Within $(document).ready(function () … I have the following window initialization:
    $(‘#jqxWindow’).jqxWindow({ theme: ‘classic’, isModal: true , width: 300, minHeight: 100, resizable: false,
    okButton: $(‘#jqxBtnOK’)
    Within $(document).ready(function () … I then tried with the following:
    $(‘#jqxWindow’).on(‘open’, function (event) {
    $(‘#jqxWindow’).jqxWindow(‘focus’);
    Resulting in no window focus when window is opened. User still have to click inside the opened window for the Esc key closure mechanism to work.
    How to set this window’s focus?
    For the Enter key to simulate the OK button click, How to set the OK button focus so that user can close window with an Enter key strike?
    Window focus setting #17275
    Hello Ivalde,
    Here is the solution:
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <link rel="stylesheet" href="../../jqwidgets/styles/jqx.summer.css" type="text/css" />
    <script type="text/javascript" src="../../../scripts/jquery-1.9.1.min.js"></script>
    <body>
    <div id='content'>
    $('#jqxwindow').on('created', function (event) {
    $('#okButton').focus()
    $("#jqxwindow").jqxWindow({ height: 90, width: 150, theme: 'summer', okButton: $('#okButton'), isModal: true });
    <button id="123">
    Open</button>
    <div id='jqxwindow'>
    <div>
    Header</div>
    <div>
    Content
    <button id="okButton">
    OK</button>
    Window focus setting #17497
    Ivalde
    Dimitar,
    Thanks a lot for the solution to this.
    For this window with this OK button, I have another question also:
    The window is to be opened when an ajax data update request is completed, for the user to be known to the completion. The window open event is then set to:
    $(‘#jqxBtnOK’).focus()
    So long so good, it does operates correct.
    However, whenever I would like to manipulate the window content for the completion msg, the okButton disappears. The code for the window content manipulation together with the window opening is set to:
    $(‘#jqxWindowOK’).jqxWindow({ content: “Detaljene er oppdatert” });
    $(‘#jqxWindowOK’).jqxWindow(‘open’);
    What then happen is that window button is gone… and I’m lost…
    Ivalde
    Window focus setting #17649
    Ivalde
    Is there no solution to this with the existing software?
    That means, whenever we would like a runtime content change, the button is missed as it belongs to the original contents now changed?
    Please confirm whether there is no solution.
    Window focus setting #17984
    Ivalde
    Do you plan for a solution to this in coming release?
    Window focus setting #18042
    Hi Ivalde,
    The button is part of the content. The solution is to attach it each time you’d like to change the content, e.g.:
    $(‘#jqxWindowOK’).jqxWindow({ content: “Detaljene er oppdatert<br /><button id='OKButton'>OK</button>” });
