jQuery UI Widgets Forums Dialogs and Notifications Window window does not destroy
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 2 months ago.
  • window does not destroy #14975
    homam
    I have a window in my code and i even copy/pasted your destroy code from window-api ref.
    but it is not work.
    my html element which in this case is a
    div
    has an id and class and i tried both even form upper scopes like
    $(body).find('#my_div').jqxWindow('destroy')
    but it is not working
    the window will close but the window functionality won’t be destroied
    can you help me plz?
    window does not destroy #14976
    Hi homam,
    You may use: $(“#window”).remove(); as a workaround.
