jQuery UI Widgets Forums Editors DateTimeInput why use div?why not use input?
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 11 years, 11 months ago.
  • why use div?why not use input? #17844
    mjohn
    Hi.
    i fund your jqxDateTimeInput Widgets is good. but is bad to use div element.
    < div id=’jqxWidget‘>
    div>
    $(“#jqxWidget”).jqxDateTimeInput({width: ‘250px’, height: ’25px’, theme: theme});
    all Widgets should use html’s form input element, then i can use jquery or other validator javascript library.
    but you use div, so this is a bad idea.
    Thanks!
    why use div?why not use input? #17846
    Hi mjohn,
    The reason the jqxDateTimeInput is created from DIV instead of from simple INPUT is that you cannot Add additional HTML Elements to INPUT tags. I do not see a problem of using it with Validation plug-ins like jqxValidator. jqxDateTimeInput has INPUT element and also works with FORMS.
