jQuery UI Widgets Forums Dialogs and Notifications Window warning window issue
This topic contains 2 replies, has 2 voices, and was last updated by  Adarsha 10 years, 7 months ago.
  • warning window issue #58849
    Adarsha
    I have below logic. Here i am trying to check how many selections were made in Combobox. Only three selections are allowed. Once 4th selection is made,
    a warning window is displayed. Display of warning widnow works fine, but below are my issues
    1. the UnselectItem is not unselecting the 4th item selected from the combobox
    2. When i manually remove the 4th item, and re-select the 4th item again, it goes into Else loop as usual and does not display warning window.
    3. The 4th item is again selected.
    Can you please suggest what is the mistake i am doing here.. thanks !
    $(“#jqxlibrarylist”).on(‘change’, function (event) {
    var items = $(“#jqxlibrarylist”).jqxComboBox(‘getSelectedItems’);
    if (items.length <= 3){
    displayNames ();
    }else
    for (var i = 0; i < items.length; i++)
    var cds = items[i].label;
    function createElements() {
    $(‘#eventWindow’).jqxWindow({
    maxHeight: 150,
    maxWidth: 280,
    minHeight: 30,
    minWidth: 250,
    height: 120,
    width: 270,
    /*resizable: false,*/
    isModal: true,
    /*modalOpacity: 0.3,*/
    okButton: $(‘#ok’),
    initContent: function () {
    $(‘#ok’).jqxButton({ width: ’65px’ });
    $(‘#ok’).focus();
    createElements();
    document.getElementById(“errmess”).innerText =’Only 3 libraries can be selected. “Ok” to close this dialog box’;
    $(“warnwindow”).css(‘visibility’, ‘visible’);
    $(“#jqxlibrarylist”).jqxComboBox(‘unselectItem’, cds);
    warning window issue #58865
    Hello adarsha,
    This code is insufficient for us to determine the source of the issue. Please provide us with a JSFiddle example we can test.
    On a side note, we do not recommend calling the window initialization code (createElements()) multiple times. Initialize it once and when you need it, call its open method.
    warning window issue #58870
    Adarsha
    am sorry i did not understand how to send the code in fiddle !! lemme expand my issue
    Step 1: Create a combobox to select the items
    // Create a jqxDropDownList
    $(“#jqxlibrarylist”).jqxComboBox({
    placeHolder: “Select libraries..”,
    theme: ‘arctic’,
    displayMember: “cdsid”,
    valueMember: “name”,
    multiSelect:true,
    autoDropDownHeight: true,
    width: 250
    Step 2. When i select the items, their values are displayed next to the combobox
    var displayNames = function(){
    if (items.length>0){var log = “Name: “;}
    else{var log = ”;}
    for (var i = 0; i < items.length; i++) {
    log += items[i].value;
    if (i < items.length – 1) {
    log += ‘, ‘;
    $(“#selectionlog”).text(log);
    Step 3: Only three items are allowed to select. Once 4th item is selected then the warning window should appear
    displayNames ();
    }else
    maxHeight: 150,
    maxWidth: 280,
    minHeight: 30,
    minWidth: 250,
    height: 120,
    width: 270,
    isModal: true,
    okButton: $(‘#ok’),
    $(‘#ok’).focus();
    createElements();
    HTML For this
    <html lang=”en”>
    <link rel=”stylesheet” href=”css/jqx.base.css” type=”text/css”>
    <link rel=”stylesheet” type=”text/css” href=”css/styles/jqx.arctic.css”>
    <link rel=”stylesheet” type=”text/css” href=”css/styles/jqx.fresh.css”>
    <body class=”default”>
    <div id=”content-wrapper”>
    <div id=’jqxWidget’>
    <div id=’jqxlibrarylist’></div>
    <div id=”selectionlog”></div>
