jQuery UI Widgets Forums Grid Virtual Scrolling with SQL and JSON
This topic contains 3 replies, has 3 voices, and was last updated by  Minko 12 years, 10 months ago.
  • Virtual Scrolling with SQL and JSON #4382
    Kloc
    I am trying to display a 24,000 row SQL table with virtual scrolling using jqxgrid in MVC 3. I am having problems getting any of my data to display. Here is my code.
    Index
    var source = {
    datafields: [{ name: 'CPT1' }, { name: 'MOD' },
    { name: 'SDESC' }, { name: 'FAGE' }, { name: 'TAGE' }, ],
    url: 'dbCPT/GetCustomers'
    var dataAdapter = new $.jqx.dataAdapter(source, { async: false, autoBind: true });
    var records = dataAdapter.records;
    $("#jqxgrid").jqxGrid({
    width: 900,
    theme: 'classic',
    virtualmode: true,
    rendergridrows: function (params) {
    var start = params.startindex;
    var end = params.endindex;
    var array = new Array();
    for (i = start; i < end; i++) {
    array[i] = records[i];
    return array;},
    { text: 'CPT Code', datafield: 'CPT1', width: 250 },
    { text: 'Modifiers', datafield: 'MOD', width: 150 },
    { text: 'Short Description', datafield: 'SDESC', width: 180 },
    { text: 'From Age', datafield: 'FAGE', width: 200 },
    { text: 'To Age', datafield: 'TAGE', width: 120 }
    Index
    Controller
    public LargeJsonResult GetCustomers()
    var dbResult = db.CPTs.ToList();
    var customers = from customer in dbResult
    select new
    customer.CPT1,
    customer.MOD,
    customer.SDESC,
    customer.FAGE,
    customer.TAGE
    return new LargeJsonResult { Data = customers, JsonRequestBehavior = System.Web.Mvc.JsonRequestBehavior.AllowGet };
    Right now all I get is an empty grid, the JSON request is working because I tried the url and had no errors. Is this the way I should be handling this large of data? The file is 2.4 MB. If you have an suggestions that would be great. I will also need to be able to enter a code and be able to jump directly to that code in the list so if you have an idea of how I can set that up it would be greatly appreciated.
    Virtual Scrolling with SQL and JSON #4383
    Hi Kloc,
    I created a sample application with ASP .NET MVC3 and jqxGrid in virtual mode.
    1. The content of the _Layout.cshtml. The different in the binding is that in your code you were mixing data bound with virtual modes. In the code below, the data adapter is separated from the Grid. The Grid knows only about the DataFields and the number of records.
    <html>
    <title>@ViewBag.Title</title>
    <link href="@Url.Content("~/Content/Site.css")"
    rel="stylesheet" type="text/css" />
    <link href="@Url.Content("~/Content/styles/jqx.base.css")"
    <link href="@Url.Content("~/Content/styles/jqx.classic.css")"
    <script src="@Url.Content("~/Scripts/jquery-1.7.2.min.js")"
    type="text/javascript"></script>
    <script src="@Url.Content("~/Scripts/jqxcore.js")"
    <script src="@Url.Content("~/Scripts/jqxbuttons.js")"
    <script src="@Url.Content("~/Scripts/jqxdata.js")"
    <script src="@Url.Content("~/Scripts/jqxgrid.js")"
    <script src="@Url.Content("~/Scripts/jqxgrid.selection.js")"
    <script src="@Url.Content("~/Scripts/jqxmenu.js")"
    <script src="@Url.Content("~/Scripts/jqxscrollbar.js")"
    var datafields = [
    { name: 'CompanyName' },
    { name: 'ContactName' },
    { name: 'ContactTitle' },
    { name: 'Address' },
    { name: 'City'}];
    // get data records.
    var source = {
    datafields: datafields,
    url: 'Home/GetCustomers'
    source: { datafields: datafields, totalrecords: records.length },
    theme: 'classic',
    virtualmode: true,
    return array;
    }, columns: [{ text: 'Company Name', datafield: 'CompanyName', width: 250 },
    { text: 'Contact Name', datafield: 'ContactName', width: 150 },
    { text: 'Contact Title', datafield: 'ContactTitle', width: 180 },
    { text: 'Address', datafield: 'Address', width: 200 },
    { text: 'City', datafield: 'City', width: 120}]
    <body>
    <div class="page">
    <div id="header">
    <div id="title">
    <h1>
    My MVC Application</h1>
    <div id="logindisplay">
    @Html.Partial("_LogOnPartial")
    <div id="menucontainer">
    <ul id="menu">
    <li>@Html.ActionLink("Home", "Index", "Home")</li>
    <li>@Html.ActionLink("About", "About", "Home")</li>
    </ul>
    <div id="main">
    @RenderBody()
    <div id="footer">
    2. In the HomeController, I added the LargeJSONResult implementation. It is important to set the MaxJsonLength to Int32.MaxValue. Otherwise, there would be not enough space for the JSON serialization.
    public class LargeJsonResult : JsonResult
    const string JsonRequest_GetNotAllowed = "This request has been blocked because sensitive information could be disclosed to third party web sites when this is used in a GET request. To allow GET requests, set JsonRequestBehavior to AllowGet.";
    public LargeJsonResult()
    MaxJsonLength = Int32.MaxValue;
    RecursionLimit = 100;
    public int MaxJsonLength { get; set; }
    public int RecursionLimit { get; set; }
    public override void ExecuteResult(ControllerContext context)
    if (context == null)
    throw new ArgumentNullException("context");
    if (JsonRequestBehavior == JsonRequestBehavior.DenyGet &&
    String.Equals(context.HttpContext.Request.HttpMethod, "GET", StringComparison.OrdinalIgnoreCase))
    throw new InvalidOperationException(JsonRequest_GetNotAllowed);
    HttpResponseBase response = context.HttpContext.Response;
    if (!String.IsNullOrEmpty(ContentType))
    response.ContentType = ContentType;
    else
    response.ContentType = "application/json";
    if (ContentEncoding != null)
    response.ContentEncoding = ContentEncoding;
    if (Data != null)
    JavaScriptSerializer serializer = new JavaScriptSerializer() { MaxJsonLength = MaxJsonLength, RecursionLimit = RecursionLimit };
    response.Write(serializer.Serialize(Data));
    3. I am using a custom class called Customer.
        public class Customer
    public Customer()
    public string CompanyName { get; set; }
    public string ContactName { get; set; }
    public string ContactTitle { get; set; }
    public string Address { get; set; }
    public string City { get; set; }
    4. In the HomeController class, the GetCustomers method creates a List of 25000 records which will be displayed in the Grid.
        public class HomeController : Controller
    public ActionResult Index()
    ViewBag.Message = "Welcome to ASP.NET MVC!";
    return View();
    public ActionResult About()
    return View();
    List<Customer> customers = new List<Customer>();
    for (int i = 0; i < 25000; i++ )
    Customer customer = new Customer(){CompanyName = "CompanyName" + i,
    ContactName = "ContactName" + i, ContactTitle = "ContactTitle" + i,
    Address = "Address" + i, City = "City" + i};
    customers.Add(customer);
    Hope this helps.
    Virtual Scrolling with SQL and JSON #4489
    Kloc
    Thanks for the reply but I am still having issues. I tried your code in a new project and everything worked fine so I’m not sure why it’s not working when I try to implement it within my code. Here is part of my LargeJsonResult when I download it.
    [{“CPT1″:”01844″,”MOD”:null,”SDESC”:”Anesth vascular shunt surg”,”FAGE”:0,”TAGE”:0},
    {“CPT1″:”01900″,”MOD”:null,”SDESC”:”Anes- inj proc hysterosalpingography (Deleted 12/31/99)”,”FAGE”:0,”TAGE”:0},{“CPT1″:”01900″,”MOD”:null,”SDESC”:”Anes- inj proc hysterosalpingography (Deleted 12/31/99)”,”FAGE”:0,”TAGE”:0},
    I have nullable and double fields, is this what might be causing the problem? Here is my new script.
    var datafields = [
    { name: 'CPT1'},
    { name: 'MOD'},
    { name: 'SDESC'},
    { name: 'FAGE'},
    { name: 'TAGE'}];
    var source = {
    theme: 'classic',
    virtualmode: true,
    return array;
    }, columns: [{ text: 'CPT Code', datafield: 'CPT1', width: 250 },
    { text: 'To Age', datafield: 'TAGE', width: 120}]
    My controller
    public class dbCPTController : Controller
    private dbCPTEntities db = new dbCPTEntities();
    public ViewResult Index()
    return View(db.CPTs.ToList());
    select new
    customer.CPT1,
    customer.MOD,
    customer.SDESC,
    customer.FAGE,
    customer.TAGE
    Any help would be appreciated!
    Virtual Scrolling with SQL and JSON #4491
    Minko
    Blocked
    Hi Kloc,
    Make sure that you’re using the last version of jQWidgets (2.2.0). Here is approach that works with the sample data that you’ve posted and jQWidgets 2.2.0:
    ViewBag.Title = "Index";
    <h2>Index</h2>
    <div id="jqxgrid"></div>
    @Html.ActionLink("Create New", "Create")
    var datafields = [{ name: 'CPT1' },
    { name: 'MOD' },
    { name: 'SDESC' },
    { name: 'FAGE' },
    { name: 'TAGE'}];
    var source = {
    url: 'Customers/GetCustomers'
    theme: 'classic',
    virtualmode: true,
    for (var i = start; i < end; i++) {
    return array;
    Here is the Controller:
    public string GetCustomers()
    return "[{\"CPT1\":\"01844\",\"MOD\":null,\"SDESC\":\"Anesth vascular shunt surg\",\"FAGE\":0,\"TAGE\":0},{\"CPT1\":\"01844\",\"MOD\":null,\"SDESC\":\"Anesth vascular shunt surg\",\"FAGE\":0,\"TAGE\":0}, {\"CPT1\":\"01844\",\"MOD\":null,\"SDESC\":\"Anesth vascular shunt surg\",\"FAGE\":0,\"TAGE\":0},{\"CPT1\":\"01844\",\"MOD\":null,\"SDESC\":\"Anesth vascular shunt surg\",\"FAGE\":0,\"TAGE\":0},{\"CPT1\":\"01900\",\"MOD\":null,\"SDESC\":\"Anes- inj proc hysterosalpingography (Deleted 12/31/99)\",\"FAGE\":0,\"TAGE\":0},{\"CPT1\":\"01900\",\"MOD\":null,\"SDESC\":\"Anes- inj proc hysterosalpingography (Deleted 12/31/99)\",\"FAGE\":0,\"TAGE\":0}]";
    Minko
    http://jqwidgets.com/
