jQuery UI Widgets Forums TreeGrid Virtual mode / AJAX. Response contain two level of data
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 7 years, 11 months ago.
  • Slava Laptev
    Hi.
    I’m trying use the TreeGrid in virtual mode with ajax.
    When widget sent first initiate request, response contain 2 level data.
    Example:
    	'id': 1,
    	'name':'test 1',
    	'parent_id':null
    	'id': 2,
    	'name':'test 2',
    	'parent_id':null
    	'id': 3,
    	'name':'test 1.1',
    	'parent_id':1
    When I expand row ‘test 1’, widget send request to server, but I can’t understand why?
    Is it possible send request to server only when I expand row ‘test 1.1’?
    My code:
    var source      = {
                    dataType  : "json",
                    dataFields: [
                        {name: 'id', type: 'number'},
                        {name: 'parent_id', type: 'number'},
                        {name: 'name', type: 'string'}
                    hierarchy : {
                        keyDataField   : {name: 'id'},
                        parentDataField: {name: 'parent_id'}
                    root      : 'data',
                    url       : 'data.php'
    $('#grid').jqxTreeGrid({
                    virtualModeCreateRecords : function (expandedRecord, done) {
                            formatData  : function (data) {
                                if (expandedRecord != null) {
                                    data.parent = expandedRecord.id;
                                return data;
                            loadComplete: function () {
                                done(dataAdapter.getRecordsHierarchy('id', 'parent_id', 'records'));
                            loadError   : function (xhr, status, error) {
                                done(false);
                                throw new Error("Error: " + error.toString());
                        dataAdapter.dataBind();
                    virtualModeRecordCreating: function (record) {
                        record.leaf = false;
                    columns                  : [
                            text         : 'name',
                            dataField    : 'name'
    Hi Slava Laptev,
    In this mode, the function is called when you expand a tree row. How you load your data then is not something the TreeGrid cares of. It depends on the developer’s own implementation.
