jQuery UI Widgets › Forums › General Discussions › Vertical Scroll Problem
This topic contains 10 replies, has 2 voices, and was last updated by Andrea 12 years ago.
AuthorVertical Scroll Problem Posts
I just started playing with jQuery Widgets. I put this under General because I wasn’t sure which widget I need to fix.
I have my screen split in a left pane and right pane.
In the right split, is a panel containing an expander. I haven’t gotten much coding done in this area yet.
In the left split, is a panel containing an expander containing a navigation bar.
My problem is that once all the menu items in my navigation bar are expanded, the nav menu/bar is vertically longer than the screen and no scroll bars appear. I have my heights set to 100%. How can I fix this?
See pic here:
http://darius.mobius-soft.com/~andrea/images/jqxscreen.jpg
Code:
$(document).ready(function () { var theme = getDemoTheme(); $("#splitter").jqxSplitter({ theme: theme, width: "99%", height: "98%", orientation: "vertical", panels: [ { size: "250px", min: 250, collapsible: true }, { size: "600px", min: 600, collapsible: false }] }); $("#cpExpander").jqxExpander({ toggleMode: "none", showArrow: false, width: "100%", height: "100%", theme: theme, initContent: function () { $("#cpNavigationBar").jqxNavigationBar({ width: "100%", height: "100%", expandMode: "multiple", expandedIndexes: [0], theme: theme }); } }); $("#contentExpander").jqxExpander({ toggleMode: "none", showArrow: false, width: "100%", height: "100%", theme: theme });});
AndreaHi Andrea,
By having a header part and widgets with 100% height below the header, the resulting height of your page will be above 100% and it is expected that you do not see the full content in that case. For creating such layout, I suggest you to see our blog post: http://www.jqwidgets.com/fluid-layout-with-fixed-header-and-footer/.
http://www.jqwidgets.com/Peter,
Thanks for your reply. I copied the sample code from the blog and it did not work for me (still no scrolling). What am I doing wrong?
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en"><head> <title>jQuery Widget Test</title> <link rel="stylesheet" href="jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../Library/js/gettheme.js"></script> <script type="text/javascript" src="../Library/js/jquery-1.8.3.min.js"></script> <script type="text/javascript" src="jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="jqwidgets/jqxsplitter.js"></script> <style type="text/css"> html, body { height: 100%; width: 100%; margin: 0px; padding: 0px; overflow: hidden; } </style> <script type="text/javascript"> $(document).ready(function () { $('#mainSplitter').jqxSplitter({ width: '100%', height: '100%', panels: [{ size: '20%' }, { size: '80%' }] }); $('#rightSplitter').jqxSplitter({ height: '100%', orientation: 'horizontal', panels: [{ size: '80%', collapsible: false }, { size: '20%' }] }); }); </script></head><body> <div style="position: absolute; width: 100%; height: 100px; background: cyan;"> Header </div> <div style="position: absolute; box-sizing:border-box; padding-top: 100px; padding-bottom: 50px; width: 100%; height: 100%;"> <div id="mainSplitter"> <div> Left Panel<br /> lots of content here to make it scroll<br /> Last line of content will in this panel will contain the word <b>END</b><br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> <b>END</b><br /> </div> <div> <div id="rightSplitter"> <div> Top-Right Panel </div> <div> Bottom-Right Panel<br /> More content<br /> And more content<br /> </div> </div> </div> </div> </div> <div style="position: absolute; bottom: 0; background: lightgreen; width: 100%; height: 50px;"> Footer </div></body></html>
Result:
http://darius.mobius-soft.com/~andrea/images/jqwidgetscreen2.jpg
You’ve hidden the scrollbars by setting overflow: hidden;
Sorry for being a pest and I know I’m not explaining this well. I want just the nav menu in the left panel to scroll vertically. I want it to be independent from the right panel (which I don’t want to scroll). When I remove the overflow, the whole page scrolls. I want just the area on the left to scroll vertically.
AndreaHi Andrea,
If you want the left panel to be scrollable, then put a scrollable DIV tag inside it or change its “overflow” property, too.
http://www.jqwidgets.com/I’m sorry for being a dolt, but I can’t seem to get it to work. Could you show me in the code I posted above what I need to add? I tried adding “overflow: scroll” to several the divs and it didn’t do what I wanted. I could also send you my test html file, if that would easier to drop the code into.
AndreaHi Andrea,
Please, find below a sample. The left panel is scrollable.
<!DOCTYPE html><html lang="en"><head> <meta name="keywords" content="jQuery Splitter, Splitter Widget, Splitter, jqxSplitter" /> <meta name="description" content="jQuery Splitter Widget - API. jqxSplitter is widget based on jQuery which provides an easy way to create dynamic layout allowing you to resize, collapse panels. These panels are actualy are HTML container's children. You can create both horizontal and vertical splitters based on your needs. This is allowing you to create complex layouts." /> <title id='Description'>jqxSplitter is a widget based on jQuery which provides an easy way to create dynamic layouts with resizable and collapsible panels.</title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.8.3.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxtree.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxsplitter.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxexpander.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <style type="text/css"> html, body { height: 100%; width: 100%; margin: 0px; padding: 0px; overflow: hidden; } </style> <script type="text/javascript"> $(document).ready(function () { $('#mainSplitter').jqxSplitter({ width: '100%', height: '100%', panels: [{ size: '20%' }, { size: '80%' }] }); $('#rightSplitter').jqxSplitter({ height: '100%', orientation: 'horizontal', panels: [{ size: '80%', collapsible: false }, { size: '20%' }] }); }); </script></head><body> <div style="position: absolute; width: 100%; height: 100px; background: cyan;"> Header </div> <div style="position: absolute; box-sizing:border-box; padding-top: 100px; padding-bottom: 50px; width: 100%; height: 100%;"> <div id="mainSplitter"> <div style="overflow: auto;"> Left Panel<br /> lots of content here to make it scroll<br /> Last line of content will in this panel will contain the word <b>END</b><br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> lots of content here to make it scroll<br />lots of content here to make it scroll<br /> <b>END</b><br /> </div> <div> <div id="rightSplitter"> <div> Top-Right Panel </div> <div> Bottom-Right Panel<br /> More content<br /> And more content<br /> </div> </div> </div> </div> </div> <div style="position: absolute; bottom: 0; background: lightgreen; width: 100%; height: 50px;"> Footer </div></body></html>
http://www.jqwidgets.com/Ok, finally I don’t feel like I’m losing my mind. Thank you so much for your patience!
I tried your solution and it did not work for me.
Here is a screen shot:
http://darius.mobius-soft.com/~andrea/images/jqwfffb.jpg
I cannot scroll down to see the “END” on the left and the right bottom panel content goes away too.
I turned off the Firefox extension Firebug:
http://darius.mobius-soft.com/~andrea/images/jqwff.jpg
Still no scrolling on the left but a little more of the bottom panel content is shown.
I turned off all extensions, plugins, and addons in Firefox. Same result (no scrolling to the “END”). I’m running Firefox 20.0 under Mac OS X. I also tried it on Firefox 20.0 and 17.0.1 under Windows. Same result.
I tried it out on Chrome, Safari, Opera (under Mac OS X), and IE (Windows) and it worked beautifully! So it seems to be a Firefox issue. Is this something you could look into so it’s compatible with Firefox? I’m writing a “proof of concept” page using your widgets. If it works, we will be writing an new user interface utilizing them. However, the majority of our users use Firefox.
For FF you should also add: -moz-box-sizing:border-box;
http://www.jqwidgets.com/Thank you, thank you, thank you!!
