jQuery UI Widgets Forums Layouts Panel and Responsive Panel Vertical and Horizontal Scrollbars in Panel
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 10 years, 11 months ago.
  • twellb
    Blocked
    I have a panel with a given size
    containing an image with the exact height
    of the panel.
    The width extends the panels width. –
    that is why a horizontal scrollbar is displayed in default mode.
    But the area at the bottom of the image is covered
    in scrollbarheight – without displaying a vertical scrollbar.
    If this is the intended behaviour – well enough.
    But if this will be modified someday I
    have to know because it would cause a lot of
    need for rewriting my code.
    What will happen?
    thomas
    Hello thomas,
    We suggest you set the panel’s height to be 18px greater than the image’s to compensate for the scrollbar, e.g.:
                // Create jqxPanel
                $("#jqxWidget").jqxPanel({ width: 350, height: 94 }); // image height is 76px
        <div id='jqxWidget' style="font-size: 13px; font-family: Verdana;">
            <img src="../../../images/slider-demo-header-background.png" />
