jQuery UI Widgets › Forums › Chart › valueAxis.unitInterval necessary for 1 data point
Tagged: auto, chart, jquery chart, jqxChart, minValue, unitInterval, valueAxis
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 9 years, 11 months ago.
when drawing a bar chart with 1 data point
nothing is drawn unless we specify unitInterval
this is not the case if the series contains 2 values
see example<!DOCTYPE html>
<html lang=”en”>
<title id=’Description’>jqxChart Column Series Example</title>
<link rel=”stylesheet” href=”../js/libs/jqwidgets-ver3.8.0/jqwidgets/styles/jqx.base.css” type=”text/css” />
<script type=”text/javascript” src=”../js/libs/jquery-1.11.1.min.js”></script>
<script type=”text/javascript” src=”../js/libs/jqwidgets-ver3.8.0/jqwidgets/jqxcore.js”></script>
<script type=”text/javascript” src=”../js/libs/jqwidgets-ver3.8.0/jqwidgets/jqxdraw.js”></script>
<script type=”text/javascript” src=”../js/libs/jqwidgets-ver3.8.0/jqwidgets/jqxchart.core.js”></script>
<script type=”text/javascript” src=”../js/libs/jqwidgets-ver3.8.0/jqwidgets/jqxdata.js”></script>
var source = [{ Country: “Spain”, GDP: 100, DebtPercent: 10, Debt: 1 }];var dataAdapter = new $.jqx.dataAdapter(source);
// prepare jqxChart settings
var settings = {
title: “Economic comparison”,
description: “GDP and Debt in 2010″,
showLegend: true,
enableAnimations: true,
xAxis:
dataField: ‘Country’,
gridLines: { visible: true },
valuesOnTicks: false
colorScheme: ‘scheme01’,
columnSeriesOverlap: false,
seriesGroups:
type: ‘column’,
valueAxis:
visible: true,
//unitInterval: 5000,
title: { text: ‘GDP & Debt per Capita($)<br>’ }
series: [
{ dataField: ‘GDP’, displayText: ‘GDP per Capita’, labels: {visible: true, angle: -90} },
//{ dataField: ‘Debt’, displayText: ‘Debt per Capita’, labels: {visible: true, angle: -90} }
// setup the chart
$(‘#chartContainer’).jqxChart(settings);
<body class=’default’>
<div id=’chartContainer’ style=”width:850px; height:500px;”>
</html>Hello rtessler,
You need either unitInterval or minValue (set, for example, to 0) to successfully plot the series. This is because the chart algorithm needs more data to automatically determine the valueAxis settings.
