jQuery UI Widgets Forums Chart ValueAxis Max and Min
This topic contains 3 replies, has 2 voices, and was last updated by  Al 10 years, 5 months ago.
  • ValueAxis Max and Min #63747
    Al
    I am confused as to how the value axis displays. I have the following setting:
    type: ‘line’,
    columnsGapPercent: 50,
    alignEndPointsWithIntervals: true,
    valueAxis:
    minValue: 2065.25,
    maxValue: 2075.25,
    unitInterval: 0.25,
    formatSettings:
    decimalPlaces: 2
    description: ‘Index Value’
    I would expect the axis to be 2075.25 – 2065.25 = 10 points long but it isn’t It seems to be sizing base don the data points int eh source array. Can I change that behavior and explicitly set the Value Axis height?
    Thanks again.
    ValueAxis Max and Min #63761
    Hello Al,
    We tested but did not experience any issues with the valueAxis minValue, maxValue and unitInterval. Here is our example:
        <script type="text/javascript" src="../../jqwidgets/jqxchart.core.js"></script>
        <script type="text/javascript" src="../../jqwidgets/jqxdraw.js"></script>
                // prepare chart data
                var sampleData = [
                        { Day: 'Monday', Keith: 30, Erica: 15, George: 25 },
                        { Day: 'Tuesday', Keith: 25, Erica: 25, George: 30 },
                        { Day: 'Wednesday', Keith: 30, Erica: 20, George: 25 },
                        { Day: 'Thursday', Keith: 35, Erica: 25, George: 45 },
                        { Day: 'Friday', Keith: 20, Erica: 20, George: 25 },
                        { Day: 'Saturday', Keith: 30, Erica: 20, George: 30 },
                        { Day: 'Sunday', Keith: 60, Erica: 45, George: 90 }
                // prepare jqxChart settings
                var settings = {
                    title: "Fitness & exercise weekly scorecard",
                    description: "Time spent in vigorous exercise",
                    source: sampleData,
                    categoryAxis:
                            dataField: 'Day',
                            showGridLines: false
                    colorScheme: 'scheme01',
                    seriesGroups:
                                type: 'line',
                                columnsGapPercent: 30,
                                seriesGapPercent: 0,
                                valueAxis:
                                    minValue: 30.5,
                                    maxValue: 40.5,
                                    unitInterval: 0.5,
                                    description: 'Time in minutes'
                                series: [
                                        { dataField: 'Keith', displayText: 'Keith' },
                                        { dataField: 'Erica', displayText: 'Erica' },
                                        { dataField: 'George', displayText: 'George' }
                // select the chartContainer DIV element and render the chart.
                $('#chartContainer').jqxChart(settings);
    <body style="background: white;">
        <div id='chartContainer' style="width: 600px; height: 800px" />
    Please make sure you are using the latest version of jQWidgets (3.6.0).
    ValueAxis Max and Min #63793
    Al
    Dimitar,
    The difference seems to be that this is not realtime. i.e. the data set is not changing. My issue boils down to:
    say I have a set of 100 last points that I want to displace, so i roll off the old point as soon as new ones arrive and refreshdata on the grid, what sets the value of the minValue and maxValue on the value axis. It seems to be jqx is computing a value based on the range of the data in the source, is that true? If not then what am i doing wrong. It is DEFINATELY not using the values specified in the settings:
    type: ‘line’,
    valueAxis:
    minValue: 2000.25,
    maxValue: 2100.25,
    unitInterval: 0.125,
    formatSettings:
    decimalPlaces: 3
    I appreciate your attention to this matter.
    ValueAxis Max and Min #63805
    Al
    Sorry, my bad again. I was not setting the unitInterval correctly.
