This topic contains 3 replies, has 2 voices, and was last updated by  Dimitar 10 years, 8 months ago.
  • validator problem #58181
    okasha
    hello sir
    i have added validation rules to the jqxvalidator but some inputs which i validate i add them to the form based on conditions
    when i click submit , the following message appear
    TypeError: c[0] is undefined
    may you help me please
    validator problem #58203
    Hello okasha,
    This most probably happens because you are trying to validate a field that has not been added to the form. A possible solution is to build the rules dynamically, too.
    validator problem #58332
    okasha
    hello Mr Dimitar
    may you tell me an example of building rules dinamically
    thank you
    okasha
    validator problem #58348
    Hi okasha,
    Here is a suggestion:
        <link rel="stylesheet" href="../../jqwidgets/styles/jqx.summer.css" type="text/css" />
        <script type="text/javascript" src="../../jqwidgets/jqxvalidator.js"></script>
                var rules = new Array();
                $("#addInput1").click(function () {
                    $('#testForm').append('<input type="text" id="userInput" class="text-input" />');
                    rules.push({ input: '#userInput', message: 'The username should be more than 3 characters!', action: 'keyup', rule: 'minLength=3' });
                    $('#testForm').jqxValidator({ rules: rules });
                    $("#addInput2").css("display", "none");
                $("#addInput2").click(function () {
                    $('#testForm').append('<input type="text" id="emailInput" class="text-input" />');
                    rules.push({ input: '#emailInput', message: 'Invalid e-mail!', action: 'keyup', rule: 'email' });
                    $("#addInput1").css("display", "none");
    <body>
        <form id="testForm" action="./">
        </form>
        <button id="addInput1">
            Add input 1</button>
        <button id="addInput2">
            Add input 2</button>
