jQuery UI Widgets Forums Grid Using valueMember
This topic contains 5 replies, has 2 voices, and was last updated by  RedantJ 9 years, 6 months ago.
  • Using valueMember #77771
    RedantJ
    (I’ll be referencing code I have already posted in a different area)
    This is pseudocode of what I would like to accomplish:
    // start pdeudocode:
    // For the column 'Room', datafield 'RoomID', displayfield 'rmSchool', columntype 'dropdownlist', width = 80
    // create editor: function (row, value, editor)
    // Let valSchoolID = selected school from the School dropdown list
    // Loop from the beginning of the adapterRooms array:
    // if (valueMember == 0) or (valueMember == valSchoolID) then
    //      add displayMember and valueMember to editor.jqxDropDownList
    // move to the next element in the array
    // End Loop
    This would be a nice feature for what we would like to accomplish. Is this currently possible?
    Using valueMember #77787
    Hello RedantJ,
    What I understand from your explanation is that you wish your dropdownlist editor to have the same source as its respective column (“Room”), including both displayMember and valueMember. If that is so, I think the approach showcased in the demo Keys/Values Column may be applicable in your case. If not, I think your pseudocode can be turned into actual, working, JavaScript. The only thing you should probably note is that one data adapter instance can be used for only one widget (the grid and the dropdownlist editor being different widgets).
    Using valueMember #77842
    RedantJ
    Hello Dimitar,
    I was able to point myself in the right direction using the jQuery API reference and examining my code closely. I can make a good guess as to what to do. Either it’s going to be something like this:
    // other code
    var cellbeginRoomEdit = function (row, datafield, columntype, value) {
    if (datafield == "rmSchool") {
    var SchoolValue = $('#jqxgrid').jqxGrid('getcellvalue', row, "bldSchool");
    <% idSchoolValue = request("SchoolValue")
    sql = "SELECT DISTINCT ROOM FROM tblROOMS WHERE School = " & idSchoolValue
    set rs = Conn.execute(sql)
    response.write "var list.....
    // more code
    { text: 'School', datafield: 'bldSchool', columntype: 'dropdownlist', width: 150 },
    { text: 'Room', datafield: 'rmSchool', columntype: 'dropdownlist', width: 150, cellbeginedit: cellbeginRoomEdit },
    ….or the code is going to look something like this:
    { text: 'Room', columngroup: 'HoldingBin', dataField: 'rmSchool', displayfield: 'RoomID', columntype: 'dropdownlist', width: 180,
    var SchoolIndex = row;
    I feel confident enough that I will find the solution that I’m looking for, thanks to the rich reference guides provided by the jQWidgets team. Cheers!
    Using valueMember #77851
    RedantJ
    I just realized that I’m going about this completely the wrong way. What I need to do is this:
    // Near the top of the code
    <% sql = "SELECT DISTINCT ROOM FROM tblROOMS WHERE"
    ….from the Server side, to pull ALL data into a two dimensional Javascript array (IE: SchoolNumber, RoomNumer) and close the Server side connection. Then, on the Client Side, figure out some way to put this into an array where jqxGrid can reference it later (IE: pull Roomnumber.value, where SchoolNumber.value = x, and place all Roomnumber.values inside the dropdown list)
    Using valueMember #77852
    RedantJ
    such as this…dagnabbit, the solution was in front of me the whole time.
    Using valueMember #77854
    RedantJ
    For the record, this solution works just perfectly:
    ` { text: ‘Room’, columngroup: ‘HoldingBin’, dataField: ‘rmSchool’, displayfield: ‘RoomID’, columntype: ‘dropdownlist’, width: 180,
    initeditor: function (row, cellvalue, editor, celltext, cellwidth, cellheight) {
    var valSchool = $(‘#jqxgrid’).jqxGrid(‘getcellvalue’, row, “bldSchool”);
    var valRoom = editor.val();
    var arrRooms = new Array();
    switch (valSchool) {
    case “fooHS”:
    <%sql = “SELECT DISTINCT ROOM FROM tblRooms WHERE SchoolCode = ‘fooHS'”
    Set rs = Conn.execute(sql)
    response.write “arrRooms = [”
    x = 0
    do until rs.eof
    if x > 0 then
    response.write “,”
    end if
    response.write chr(34) & rs.Fields(“ROOM”).value & chr(34) & “, ”
    x = x + 1
    rs.movenext
    loop
    response.write “];”%>
    break;
    editor.jqxDropDownList({ autoDropDownHeight: true, source: arrRooms });
    if (arrRooms != “Select a room…”) {
    var index = arrRooms.indexOf(valRoom);
    editor.jqxDropDownList(‘selectIndex’, index);
