jQuery UI Widgets Forums Grid Using showfilterrow , groupable and autoloadstate
This topic contains 4 replies, has 2 voices, and was last updated by  DeployDuck 5 years, 9 months ago.
  • DeployDuck
    I have been given the task by my management to check, in the future we should change to jqxWidgets for our products. At the moment I am trying to work out if jqxGrid meets our requirements.
    I’m stuck with the following situation:
    The grid should have a filter line and also the groupable function.
    The status of the grid should e.g. after a change / update of the data source can be restored.
    This is my columns definition:
    CustomerListGridColumns: [
        { text: 'Customer',     datafield: 'customername' ,    width: 200  },
        { text: 'CustomerNo',   datafield: 'customerno',       width: 100  },
        { text: 'State',        datafield: 'customerstate',
                                displayfield: 'displaystate',
                                columntype: 'dropdownlist',
                                width: 180,
                                filtertype: 'checkedlist'  },
        { text: 'City',         datafield: 'city',
                                displayfield: 'displaycity',
                                columntype: 'dropdownlist' ,
    I use a data adapter, which provides the grid with data.
    $(document).ready(function(){
        function CustomerListGrid(GridDateaSource){
           $("#MyCustomerGridID").jqxGrid({
               width: '100%',  height: '100%',
               source: GridDateaSource,
               showfilterrow: true,
               autosavestate : true,
               autoloadstate: true,
               groupable: true,
               showgroupmenuitems: true,
               showsortmenuitems: false,
               columns:  CustomerListGridColumns,
               selectionmode :"singlerow",
               pagesize: 25,
               pagesizeoptions: ["10","25","50","100"],
               localization: AllGridLocalStringObj,
               theme: GridTheme
        DataAdapter_CustomerList(data).then(function(DataSource) { CustomerListGrid(DataSource); });
    When using showfilterrow AND groupable together, I get the following error message as a result:
    Uncaught (in promise) TypeError: Cannot read property ‘style’ of undefined from jqxgrid.filter.js
    The error disapears, if I remove autoloadstate.
    If I either disable showfilterrow or groupable, it almost works: Only the last column “City”, which should actually extend to the right border of the grid, is now only displayed with a width of 73px and no longer expanded.
    I am happy about every proposed solution, which allows me to use all three functions together.
    The DeployDuck
    Todor
    Hello DeployDuck,
    From your sample code I cannot see where you’re using jqxDataAdapter. You could review the following docs with different Grid Data Sources and how to set the jqxDataAdapter according to your use case. I think the whole issue comes from not using the jqxDataAdapter correctly.
    Todor
    https://www.jqwidgets.com
    DeployDuck
    Hello Todor,
    thank you for your answer. I just read the docs but unfortunately I’m not quite smart, which is wrong with my approach. sorry.
    In order to clarify where my problem lies, I have created a simplified example that shows the faulty behavior.
    https://jsfiddle.net/DeployDuck/y1p692re/
    To reproduce the error, drag a column into the grouping area and then run again.
    You receive the error message:
    Uncaught TypeError: Cannot read property 'style' of undefined
        at d (jqx-all.js:97)
        at c.<computed>._updatefilterrowui (jqx-all.js:97)
        at c.<computed>._updatefilterrow (jqx-all.js:97)
        at c.<computed>._rendercolumnheaders (jqx-all.js:83)
        at c.<computed>.rendergridcontent (jqx-all.js:83)
        at c.<computed>._loadselectionandcolumnwidths (jqx-all.js:95)
        at c.<computed>.loadstate (jqx-all.js:95)
        at o (jqx-all.js:83)
        at b.jqx.dataview.dataview.update (jqx-all.js:83)
        at n (jqx-all.js:83)
    I’m glad if you please point me to the right direction.
    Many Thanks.
    The DeployDuck
    Todor
    Hello DeployDuck,
    It seems that this is an issue. We have created a work item for this case.
    Thank you for the feedback!
    Todor
    DeployDuck
    Hello Todor,
    can you please let me know as soon as there is a solution or workaround.
    Thank you.
    DeployDuck
