jQuery UI Widgets Forums Grid using setcellvalue without updating record
This topic contains 1 reply, has 2 voices, and was last updated by  Christopher 8 years, 9 months ago.
  • rasoul_par
    Hi
    I need to show a popup window (which contains a grid) when some specific columns are in edit mode.
    when user DbClicks on rows of shown grid I have to set value of selected row to current cell (which I have shown a grid for it).
    There is no problem so far, but when I want to update value of cell by using setcellvalue the entire row updates, this is not the functionality that I need. I want to update entire row after selected row changed.
    Can anybody provide some help/documentation about setcellvalue or suggest a new approach?
    Christopher
    Hi rasoul_par,
    “setcellvalue” updates only a cell’s value. It doesn’t update the whole row. To update an entire row after making changes to it you need to call the method “updaterow”. Please send a snippet of your code to better understand the problem that you are facing.
    Christopher
