jQuery UI Widgets › Forums › Lists › DropDownList › Using lookup tables – selectedIndex not right…
Tagged: data adapter, DropDownList, jqxDropDownList, lookup table, placeHolder, source
This topic contains 7 replies, has 2 voices, and was last updated by atrumm 10 years, 3 months ago.
Hi! I hope I can explain this right. I’m using jqWidgets to create a fairly simple table showing data from a table. Users can click “edit” and edit this data. One of the fields is an id that refers to a lookup table, so I’m trying to use a drop down list with jqxDropDownList.
Everything is working except one aspect. When I select the record and go to its page, the dropdown list isn’t showing what’s in the database – that is, it says “please choose”
For example – Here are three records from the lookup table:
var crsSource = [{ CrsID: 2000, CrsName: "Anguilla 1957 / British West Indies Grid" }, { CrsID: 2001, CrsName: "Antigua 1943 / British West Indies Grid" }, { CrsID: 2002, CrsName: "Dominica 1945 / British West Indies Grid" }];
In my main table, I will store the CrsID – so for example I store 2002. In my dropdownlist I should see “Dominica 1945…” – instead I see “please choose” (or if I define selectedIndex as 0 I’ll see “Anguila 1957…” – but the data is storing correctly…
Here’s the rub – if instead of getting my dropdown list data from my look up table, I try using a local array like the one above… – it works exactly as expected. I’ll paste the code I’m trying to get to work:
var crsSource = { datatype: "json", datafields: [ { name: 'CrsID' }, { name: 'CrsName' } ], id: 'epsg_crs_id', url: '<?php echo URL; ?>well/fillEpsgCrsDropdown' }; var crsAdapter = new $.jqx.dataAdapter(crsSource, { autoBind: true }); $("#jqxpanel").jqxPanel({theme: theme, width: '97%', height: '97%'}); // Create a jqxMenu $("#appMenu").jqxMenu({theme: theme, width: '100%'}); $("#WellID").jqxInput({theme: theme, width: 120, disabled: true}); $("#WellName").jqxInput({theme: theme, width: 120, disabled: (wellID == 'add' ? false : true)}); $("#API").jqxInput({theme: theme, width: 120, disabled: (wellID == 'add' ? false : true)}); $("#CompanyUWI").jqxInput({theme: theme, width: 120, disabled: (wellID == 'add' ? false : true)}); $("#Easting").jqxInput({theme: theme, width: 120, disabled: (wellID == 'add' ? false : true)}); $("#Northing").jqxInput({theme: theme, width: 120, disabled: (wellID == 'add' ? false : true)}); $("#Latitude").jqxInput({theme: theme, width: 120, disabled: (wellID == 'add' ? false : true)}); $("#Longitude").jqxInput({theme: theme, width: 120, disabled: (wellID == 'add' ? false : true)}); $("#CRS").jqxDropDownList({ source: crsAdapter, displayMember: 'CrsName', valueMember: 'CrsID', theme: theme, width: 250, placeHolder: "Empty. Please Select:", disabled: (wellID == 'add' ? false : true) }); $("#Surveys").jqxButton({theme: theme, width: 120}); $("#Plans").jqxButton({theme: theme, width: 120}); $("#Cancel").jqxButton({theme: theme, width: 120}); $("#Save").jqxButton({theme: theme, width: 120}); //$("#Save").hide(); (wellID == 'add' ? $("#Save").show() : $("#Save").hide()); } function enableFormControlsForEditing() { $("#Save").show(); $("#Cancel").val('Cancel'); $("#WellName").jqxInput({disabled: false}); $("#API").jqxInput({disabled: false}); $("#CompanyUWI").jqxInput({disabled: false}); $("#Easting").jqxInput({disabled: false}); $("#Northing").jqxInput({disabled: false}); $("#Latitude").jqxInput({disabled: false}); $("#Longitude").jqxInput({disabled: false}); $("#CRS").jqxDropDownList({disabled: false}); } function disableFormControls() { $("#Save").hide(); $("#Cancel").val('Edit'); $("#WellName").jqxInput({disabled: true}); $("#API").jqxInput({disabled: true}); $("#CompanyUWI").jqxInput({disabled: true}); $("#Easting").jqxInput({disabled: true}); $("#Northing").jqxInput({disabled: true}); $("#Latitude").jqxInput({disabled: true}); $("#Longitude").jqxInput({disabled: true}); $("#CRS").jqxDropDownList({disabled: true}); }
and of course a bunch of divs and such in the html – and php loading this data and etc – like I said, it all works except the selection index… thanks in advance – I know this is clear as mud!
Hello atrumm,
Are you sure the data is correctly loaded from your source? You can check this with the data adapter’s callback functions loadError and loadComplete. And something else – does the dropdownlist display “please choose” or the placeHolder you have actually set – “Empty. Please Select:”?
http://www.jqwidgets.com/Hi Dimitar!
I’m pretty sure it’s loading the data correctly because the dropdown is right and I can go to the url and see the array – that looks right – I haven’t tried loadError and loadComplete – maybe I’ll try that and I see what I get. Oh yes the dropdown list displays my placeHolder – sorry I forgot that I had changed that…
UPDATE: using loadComplete and loadError it seems the data is loading right…
Hi atrumm,
Could you, please, specify the JSON output from the url? Maybe it needs to be mapped to be loaded correctly by the dropdownlist.
http://www.jqwidgets.com/Good morning Dimitar!
Well let’s see..
[{“CrsID”:”4143″,”CrsName”:”Abidjan 1987″},{“CrsID”:”61436405″,”CrsName”:”Abidjan 1987 (deg)”},{“CrsID”:”2165″,”CrsName”:”Abidjan 1987 \/ TM 5 NW”}]
That’s a small piece – the table is big – but that’s how it looks…
– A
Hi A,
We tried to reproduce the issue but to no avail: http://jsfiddle.net/Dimitar_jQWidgets/k5uh4mp6/. Everything works fine if the data is locally loaded, as you already stated. If this is the only difference between the working and non-working dropdownlists, the issue may be due to your server-side code. Some things you may try are removing autoBind or setting the source async field to false.
Thanks a bunch for the help… removing autoBind did nothing but setting async to false seems to have worked! Very interesting – and I suppose that makes sense, but I couldn’t explain why!
Thanks again for the help!
— A
