jQuery UI Widgets Forums Gauges and Maps TreeMap Using JSON with Treemap
This topic contains 4 replies, has 2 voices, and was last updated by  robf 10 years, 11 months ago.
  • Using JSON with Treemap #54852
    robf
    I have a question about using the treemap with json.
    I was able to use the homeprices.txt file (with datatype=’tab’) and this works fine, per your example. I then converted the file to json e.g.
        1951,
        103.8986687,
        59.2786986,
        154.287,
        0.0257
        1952,
        103.9743275,
        58.94343772,
        156.954,
        0.0268
        1953,
        113.8451588,
        60.8392201,
        159.565,
        0.0283
        1954,
        115.6204181,
        62.25447619,
        162.391,
        0.0248
        1955,
        115.5419272,
        65.95528267,
        165.275,
        0.0261
        1956,
        113.7942463,
        68.79148786,
        168.221,
        0.029
    The code is then:
                          { name: 'Year' },
                          { name: 'HPI' },
                          { name: 'BuildCost' },
                          { name: 'Population' },
                          { name: 'Rate' }
                     url: 'homeprices.json'
                var dataAdapter = new $.jqx.dataAdapter(source, { async: true, autoBind: true, loadError: function (xhr, status, error) { alert('Error loading "' + source.url + '" : ' + error); } });
            $('#treemap').jqxTreeMap({
                    width: '600',
                    height: '500',
                    displayMember: 'Year',
                    valueMember: 'Rate',
                    colorMode: 'rangeColors',
                    colorRanges: [
                        { min: 0.02, max: 0.03, color: '#ff0300' },
                        { min: 0.03, max: 0.04, color: '#fe2e00' },
                        { min: 0.04, max: 0.05, color: '#fe3900' },
                        { min: 0.05, max: 0.06, color: '#ff5400' },
                        { min: 0.06, max: 0.07, color: '#fe7500' },
                        { min: 0.07, max: 0.08, color: '#fe8200' },
                        { min: 0.08, max: 0.09, color: '#ffed00' },
                        { min: 0.09, max: 0.1, color: '#b8db00' },
                        { min: 0.1, max: 0.11, color: '#7fbf00' },
                        { min: 0.11, max: 0.12, color: '#50a600' },
                        { min: 0.12, max: 0.15, color: '#008000' }
                    legendScaleCallback: function (v) {
                        return v;
                    renderCallbacks: {
                        '*': function (element, data) {
                            var content = '<div><div style="font-weight: bold; font-family: verdana; font-size: 13px;">Year: ' + data.record.Year + '</div>';
                            content += '<div style=" font-family: verdana; font-size: 12px;">HPI: ' + data.record.HPI + '</div>';
                            content += '<div style=" font-family: verdana; font-size: 12px;">Build Cost: ' + data.record.BuildCost + '</div>';
                            content += '<div style=" font-family: verdana; font-size: 12px;">Population: ' + data.record.Population + '</div>';
                            content += '<div style=" font-family: verdana; font-size: 12px;">Interest Rate: ' + data.record.Rate + '</div>';
                            content += '</div>';
                            element.jqxTooltip({
                                content: content,
                                position: 'mouse',
                                autoHideDelay: 6000
                    legendLabel: 'Interest Rate'
    When I try to execute this code my request just runs indefinitely in the browser. I have tried a similar operation with the “coffee” example and file – e.g.
        "id": "2",
        "parentid": "1",
        "text": "Hot Chocolate",
        "value": "$5.2"
        "id": "3",
        "parentid": "1",
        "text": "Peppermint Hot Chocolate",
        "value": "$4.0"
        "id": "4",
        "parentid": "1",
        "text": "Salted Caramel Hot Chocolate",
        "value": "$2.4"
    Not sure what the issue is. My JSON validates fine via JSONLint. Any help appreciated!
    Thanks.
    Rob
    Using JSON with Treemap #54893
    Hello Rob,
    Is any error alerted by the data adapter which loads the JSON? Do you experience any issues trying to run the demo Binding to JSON?
    Using JSON with Treemap #55057
    robf
    Hello Dimitar,
    Thank you kindly for your response. I do not get any error from the data adapter. I have used the ‘COFFEE’ example from your site as follows
    <body>
        <div id='content'>
                    var theme = "";
                    var url = 'coffee.json';   //toggle use of this ** see below
                    var data = [
                        "id": "2",
                        "parentid": "1",
                        "value": "$5.2"
                        "id": "3",
                        "parentid": "1",
                        "value": "$4.0"
                        "id": "4",
                        "parentid": "1",
                        "value": "$2.4"
                        "id": "5",
                        "parentid": "1",
                        "text": "White Hot Chocolate",
                        "value": "$2.5"
                        "text": "Chocolate Beverage",
                        "id": "1",
                        "parentid": "-1",
                        "value": "$1.1"
                        "id": "6",
                        "text": "Espresso Beverage",
                        "parentid": "-1",
                        "value": "$0.9"
                        "id": "7",
                        "parentid": "6",
                        "text": "Caffe Americano",
                        "value": "$1.2"
                        "id": "8",
                        "text": "Caffe Latte",
                        "parentid": "6",
                        "value": "$3.3"
                        "id": "9",
                        "text": "Caffe Mocha",
                        "parentid": "6",
                        "value": "$2.5"
                        "id": "10",
                        "text": "Cappuccino",
                        "parentid": "6",
                        "value": "$1.5"
                        "id": "11",
                        "text": "Pumpkin Spice Latte",
                        "parentid": "6",
                        "value": "$1.6"
                        "id": "12",
                        "text": "Frappuccino",
                        "parentid": "-1"
                        "id": "13",
                        "text": "Caffe Vanilla Frappuccino",
                        "parentid": "12",
                        "value": "$1.2"
                            { name: 'id' },
                            { name: 'parentid' },
                            { name: 'text' },
                            { name: 'value' }
                        localdata: data     // ** when I use this it works
                        //url: url          // if I comment out 'localdata' and use the url it simply hangs
                    // create data adapter.
                    // perform Data Binding.
                    dataAdapter.dataBind();
                    // get the treemap sectors. The first parameter is the item's id. The second parameter is the parent item's id. The 'items' parameter represents
                    // the sub items collection name. Each jqxTreeMap item has a 'label' property, but in the JSON data, we have a 'text' field. The last parameter
                    // specifies the mapping between the 'text' and 'label' fields.
                    var records = dataAdapter.getRecordsHierarchy('id', 'parentid', 'items', [{ name: 'text', map: 'label'}]);
                        width: 600,
                        height: 600,
                        source: records,
                        baseColor: '#0afaaa',
                        renderCallbacks: {
                                if (!data.parent) {
                                    element.css({
                                        backgroundColor: '#fff',
                                        border: '1px solid #aaa'
                                else {
                                    var nThreshold = 105;
                                    var bgDelta = (data.rgb.r * 0.299) + (data.rgb.g * 0.587) + (data.rgb.b * 0.114);
                                    var foreColor = (255 - bgDelta < nThreshold) ? 'Black' : 'White';
                                    element.css({
                                        color: foreColor
            <div id='treemap'>
    I created a ‘coffee.json’ file that mirrors the data array (and is valid json)
        "id": "2",
        "parentid": "1",
        "value": "$5.2"
        "id": "3",
        "parentid": "1",
        "value": "$4.0"
        "id": "4",
        "parentid": "1",
        "value": "$2.4"
        "id": "5",
        "parentid": "1",
        "value": "$2.5"
        "id": "1",
        "parentid": "-1",
        "value": "$1.1"
        "id": "6",
        "parentid": "-1",
        "value": "$0.9"
        "id": "7",
        "parentid": "6",
        "value": "$1.2"
        "id": "8",
        "parentid": "6",
        "value": "$3.3"
        "id": "9",
        "parentid": "6",
        "value": "$2.5"
        "id": "10",
        "parentid": "6",
        "value": "$1.5"
        "id": "11",
        "parentid": "6",
        "value": "$1.6"
        "id": "12",
        "parentid": "-1"
        "id": "13",
        "parentid": "12",
        "value": "$1.2"
    As I say, I see no errors in Firebug, but when I use URL it will not load treemap.
    Any further help is greatly appreciated!
    Thank you.
    Rob
    Using JSON with Treemap #55060
    Hi Rob,
    This behaviour occurs because loading from an external data source is slower and by the time you are setting records, the data adapter has not yet finished loading the data. Please set the async source property to false and your issue should be solved, i.e.:
            { name: 'id' },
            { name: 'text' },
            { name: 'value' }
        url: url,
        async: false
    Using JSON with Treemap #55147
    robf
    Excellent. That did it. Thank you!
    Robert
