jQuery UI Widgets Forums Grid Using Hidden Field for population
This topic contains 2 replies, has 2 voices, and was last updated by  trensic 11 years, 8 months ago.
  • Using Hidden Field for population #28123
    trensic
    Newbie Question:
    I am storing arrays in a hidden field and want to use that from populating data.
    To save the array:
    var myArray = new Array();
    myArray[0] = “Nancy” ,
    myArray[1] = “Andrew”,
    myArray[2] = “Janet”,
    myArray[3] = “Margaret”,
    myArray[4] = “Steven”,
    myArray[5] = “Michael”,
    myArray[6] = “Robert”,
    myArray[7] = “Laura”,
    myArray[8] = “Anne”
    document.getElementById(“firstname_ary”).value = JSON.stringify(myArray);
    When I am calling the values:
    var firstNames = document.getElementById(“firstname_ary”).value;
    (so that looks like [“Nancy”, “Andrew”, “Janet”, ….”])
    The First name field comes out with each character in the array apposed to the name so each row looks like this:
    1:[
    2:”
    3:N
    4:a
    5:…you get the idea
    Soooo how can I use the array in the hidden field?
    Using Hidden Field for population #28132
    Hello trensic,
    The issue comes from the stringify method, which turns the array into string when you actually need it to be an array. Here is an example, based on the demo Binding to Array, that shows you do not need the stringify:
    var theme = "";
    var data = new Array();
    myArray[0] = "Nancy",
    myArray[1] = "Andrew",
    myArray[2] = "Janet",
    myArray[3] = "Margaret",
    myArray[4] = "Steven",
    myArray[5] = "Michael",
    myArray[6] = "Robert",
    myArray[7] = "Laura",
    myArray[8] = "Anne";
    var firstNames = new Array();
    firstNames = myArray;
    var lastNames =
    var productNames =
    var priceValues =
    for (var i = 0; i < 200; i++) {
    var row = {};
    row["price"] = price;
    row["quantity"] = quantity;
    data[i] = row;
    localdata: data,
    datatype: "array",
    datafields:
    $("#jqxgrid").jqxGrid(
    width: 670,
    { text: 'Name', dataField: 'firstname', width: 100 },
    { text: 'Last Name', dataField: 'lastname', width: 100 },
    { text: 'Product', editable: false, dataField: 'productname', width: 180 },
    { text: 'Quantity', dataField: 'quantity', width: 80, cellsalign: 'right' },
    { text: 'Unit Price', dataField: 'price', width: 90, cellsalign: 'right', cellsformat: 'c2' },
    { text: 'Total', dataField: 'total', cellsalign: 'right', minwidth: 100, cellsformat: 'c2' }
    <div id='jqxWidget'>
    <div id="jqxgrid">
    Using Hidden Field for population #28154
    trensic
    Thank you … I was not taking my hidden field value and turning it into an Array as well so that is fixed and fixed.
