jQuery UI Widgets › Forums › Dialogs and Notifications › Window › Using a Percent for Height
This topic contains 8 replies, has 3 voices, and was last updated by BrentH 10 years, 6 months ago.
In my set up I would like the height to be a percent as such:
$('#layersWindow').jqxWindow({ width: 320, height: '75%', resizable: true, autoOpen: false });
This works great for the outer boundary, but the form’s content doesn’t resize as I change the browser size. Any ideas?
<div id="layersWindow"> <div id="layersWindowHeader"> <span id="captureContainer" style="float: right">Layer Controls and Legend</span> </div> <div id="layersWindowContent" style="height: 100%" > Content... </div> </div>
Hello BrentH,
What kind of content do you have in your window? We would like to test for the reported behaviour with it. Please also note that the window’s height can be no less than its minHeight setting.
http://www.jqwidgets.com/My content is a tree view.
You can see the issue with this script (it’s as short as I can make it). You can drag the bottom of the browser up and down to see the issue. You lose elements from the tree view. There is one image in there, but the source is irrelevant – just point to anything.<!DOCTYPE html> <html lang="en"> <head> <meta charset="utf-8" /> <meta name="keywords" content="Sample Content Not Resizing" /> <title id='Description'>Sample Content Not Resizing</title> <link rel="stylesheet" href="../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="jquery-1.11.1.min.js"></script> <script type="text/javascript" src="../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../jqwidgets/jqxwindow.js"></script> <script type="text/javascript" src="../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="../jqwidgets/jqxtree.js"></script> <script type="text/javascript" src="../jqwidgets/jqxsplitter.js"></script> <script type="text/javascript"> var _layerwinpos = 0; var geoViewDemo = (function () { var _collapsed = false; function _addEventListeners() { $('#OpenToolBoxWindow').mousedown(function () { $('#toolBoxWindow').jqxWindow('expand'); $('#toolBoxWindow').jqxWindow('open'); }); }; function _createWindows() { $('#toolBoxWindow').jqxWindow({ width: 320, height: '50%', resizable: true, autoOpen: false }); $("#toolBoxWindow").jqxWindow('move', 40, 4); }; function _createLayersTree() { $('#jqxTree').jqxTree({ height: '100%', width: '100%', hasThreeStates: false, checkboxes: false }); $("#jqxTree").jqxTree('selectItem', $("#home")[0]); }; return { init: function () { _createWindows(); _createLayersTree(); _addEventListeners(); } }; } ()); $(document).ready(function () { geoViewDemo.init(); }); </script> </head> <body class='default'> <img id="OpenToolBoxWindow" style="position: absolute; top: 4px; left: 4px; visibility: visible; width: 30px; height: 30px" src="../Images/ExpandContract/toolbox48.png" alt="Show Toolbox" /> <div id="toolBoxWindow"> <div id="toolBoxWindowHeader"> <span id="captureContainer" style="float: left">Map Tools</span> </div> <div id="toolBoxWindowContent" style="height: 100%;"> <div id='jqxTree'> <ul> <li id='home'>Home</li> <li id="solutions" item-checked='true' item-expanded='true'> Solutions <ul> <li id="education"> <input type="checkbox" style="padding: 0px; margin: 0px;"></checkbox> Education</li> <li id="financial services"> Financial services</li> <li id="government"> <img style='float: left; margin-right: 5px;' src='../images/calendarIcon.png' /><span item-title="true">Calendar</span> </li> <li item-checked='false'>Manufacturing</li> <li>Solutions <ul> <li>Consumer photo and video</li> <li>Mobile</li> <li>Rich Internet applications</li> <li>Technical communication</li> <li>Training and eLearning</li> <li>Web conferencing</li> </ul> </li> <li>All industries and solutions</li> </ul> </li> <li>Products <ul> <li>PC products</li> <li>Mobile products</li> <li>All products</li> </ul> </li> <li>Support <ul> <li>Support home</li> <li>Customer Service</li> <li>Knowledge base</li> <li>Books</li> <li>Training and certification</li> <li>Support programs</li> <li>Forums</li> <li>Documentation</li> <li>Updates</li> </ul> </li> </ul> </div> </div> </div> </body> </html>
Hi BrentH,
Thank you for your feedback. We will investigate this behaviour and if we confirm it as an issue, we will fix it as soon as possible.
http://www.jqwidgets.com/Hi guys,
The content in jqxWindow depends on the size of jqxWindow, not on the size of the browser’s window and that is because the container of the jqxWindow’s content is jqxWindow. This means that if you resize the browser’s window in that case, nothing should happen. Sample based on your code: http://jsfiddle.net/jqwidgets/e2kwj4r0/
http://www.jqwidgets.com/Your sample shows the same thing that I showed in my sample. You didn’t fix anything.
Using your link in the previous post, Open up all of the tree nodes and scroll to where you can see “Documentation” and “Updates”.
Then grab the bottom of your browser and drag it halfway up your monitor screen.
Now try to access “Updates” or “Documentation”
Do you see the real issue now?Brent
OK, I tried it in Chrome and it works, but in IE 10 the problem still exists. Haven’t tried another browser.
Hello BrentH,
Ok, update this fiddle one more time: http://jsfiddle.net/1owwvLxc/. If we find erroneous behavior on our side, we will add a work item about it for a future jQWidgets update.
http://www.jqwidgets.com/Thanks
This last sample is only missing:
$(window).resize(function () { ... $('toolBoxWindow').jqxWindow({ height: $(window).height()/2 }); });
