jQuery UI Widgets Forums Lists ComboBox Using a form input field as a combobox
This topic contains 4 replies, has 2 voices, and was last updated by  WarLoc3D 12 years, 3 months ago.
  • Using a form input field as a combobox #12514
    WarLoc3D
    I wanted to combine the combox directly into an input field, but it doesnt work (latest version). I couldnt find anything on the topic in this forum, internet or the documentation and maybe the combobox is only restricted to the div element. Maybe i have to overcome this by using jquery but any help on this matter is appreciated. I included a small rundown example which works on divs but not on inputs.
    Using a form input field as a combobox #12525
    Hi WarLoc3D,
    How did you test with Combobox? Could you paste a code and use the button to format it? Did you set the “name” attribute to the ComboBox’s DIV tag?
    Using a form input field as a combobox #12531
    WarLoc3D
    <link rel="stylesheet" href="./jqwidgets/jqwidgets/styles/jqx.base.css" type="text/css" />
    <link rel="stylesheet" href="./jqwidgets/jqwidgets/styles/jqx.classic.css" type="text/css" />
    <script type="text/javascript" src="./jqwidgets/scripts/jquery-1.8.0.min.js"></script>
    <script type="text/javascript" src="./jqwidgets/jqwidgets/jqxcore.js"></script>
    <script type="text/javascript" src="./jqwidgets/jqwidgets/jqxbuttons.js"></script>
    <script type="text/javascript" src="./jqwidgets/jqwidgets/jqxscrollbar.js"></script>
    <script type="text/javascript" src="./jqwidgets/jqwidgets/jqxlistbox.js"></script>
    <script type="text/javascript" src="./jqwidgets/jqwidgets/jqxcombobox.js"></script>
    <script type="text/javascript" src="./jqwidgets/jqwidgets/globalization/jquery.global.js"></script>
    <script type="text/javascript" src="./jqwidgets/scripts/gettheme.js"></script>
    var data = {};
    var theme = 'classic';
    var source = [
    "NEW",
    "STOCK",
    "TEMPORARY",
    $("#jqxComboBox").jqxComboBox({ source: source, selectedIndex: 0, width: '250', height: '25px', theme: theme });
    <body>
    <div>
    <div><input id="jqxComboBox"></input></div>
    Using a form input field as a combobox #12533
    Hi WarLoc3D,
    jqxComboBox requires a DIV tag to be initialized. It is not possible to initialize it from Input tag. Please, take a look at the help topic here: jquery-combobox-getting-started.htm
    Using a form input field as a combobox #12534
    WarLoc3D
    Okay, thanks for the reply. Was afraid this was the way it is.
