jQuery UI Widgets Forums DataTable UpdateRow Commit Problem
This topic contains 3 replies, has 3 voices, and was last updated by  Dimitar 8 years, 9 months ago.
  • UpdateRow Commit Problem #68729
    drtzack
            updaterow: function (rowID, rowData, commit) {
                    type: "POST",
                    dataType: 'json',
                    cache: false,
                    async: false,
                    url: '/api/order/update',
                    data: rowData,
                        commit(true);
    Here is my code. if I set async to true, it’s not showing the changes unless I refresh the page.
    UpdateRow Commit Problem #68789
    Hello drtzack,
    Note that the name of the data table source callback is updateRow, not updaterow. Please correct this and share if the issue persists.
    UpdateRow Commit Problem #85933
    edd
    Can anybody help me to with what i need to write to get on server the add edit reset row ?
    //synchroniza with the server – send update command
    data = “update=true” +
    “&ID_CUSTOMERS=” + rowdata.ID_CUSTOMERS +
    “&CompanyName=” + rowdata.CompanyName +
    “&ContactTitle=” + rowdata.ContactTitle +
    “&City=” + rowdata.City +
    “&Country=” + rowdata.Country +
    “&Address=” + rowdata.Address +
    “&DateOfBirth=” + rowdata.DateOfBirth;
    //rowdata.id = rowid;
    dataType: ‘json’,
    //cache: false,
    url: ‘WebService1.asmx/GetCustomers’,
    data: rowdata,
    type: “POST”,
    commit(true);
    //commit(true, data.id);
    alert(‘Worked!’);
    // update failed.
    commit(false);
    alert(‘Did not work’);
    commit(true);
    addrow : function (rowid, rowdata) {
    var observableArray = self.myData.arrayA,
    record = null;
    observableArray.push({ dateFrom: null, dateTo: null, duration: null, text: null, code: null, currency: null });
    record = observableArray()[rowid];
    for (var obj in record) {
    record[obj] = ko.observable(record[obj]);
    ko.mapping.fromJS(observableArray(), {}, self.myData.arrayA());
    deleterow : function (rowid) {
    var observableArray = self.myData.arrayA;
    observableArray.remove(observableArray()[rowid]);
    I need to write anything else on default.aspx.cs to can see on the server sql?
    UpdateRow Commit Problem #85961
    Hello edd,
    Please note my previous post in this topic. If you are using jqxDataTable, the source callback functions in question are called updateRow, addRow and deleteRow. Please also note that there has to be a comma between the definitions of addRow and deleteRow.
    You can see a working CRUD example (but with jqxGrid) that features both client- and server-side implementations here: http://www.jqwidgets.com/jquery-widgets-documentation/documentation/asp.net-integration/asp.net-grid-crud.htm.
