jQuery UI Widgets Forums Grid Uncaught TypeError: Cannot read property 'length' of undefined
This topic contains 2 replies, has 2 voices, and was last updated by  selva 11 years, 1 month ago.
  • selva
    Dynamically I created a new row and set values for cells.The new empty row was generated after that i set values for that row at that time i got this below error.
    Uncaught TypeError: Cannot read property ‘length’ of undefined
    Here is my code for your reference:
    var source = {
                            {name: 'advertiserId', type: 'string'},
                            {name: 'advertiserName', type: 'string'}
                    var gridAdapter = new $.jqx.dataAdapter(source);
    $('#brand_grid_edit').jqxGrid(
                                width: 500,
                                height: 250,
                                autoshowfiltericon: true,
                                theme: theme_name,
                                source: gridAdapter,
                                showtoolbar: true,
                                toolbarheight: 25,
                                rendertoolbar: function(toolbar) {
                                    var me = this;
                                    var container = $("<div style='margin: 5px;'></div>");
                                    var addButton = $("<div style='float: left; margin-left: 5px;margin-top:-4px;' title='Add Row'><img style='position: relative; margin-top: 0px;' src='jqx/images/add.png'/></div>");
                                    var deleteButton = $("<div style='float: left; margin-left: 5px;margin-top:-4px;' title='Delete Row'><img style='position: relative; margin-top: 0px;' src='jqx/images/minus.png'/></div>");
                                    toolbar.append(container);
                                    container.append(addButton);
                                    container.append(deleteButton);
                                    addButton.jqxButton({width: 20, height: 15, theme: theme_name});
                                    deleteButton.jqxButton({width: 20, height: 15, theme: theme_name});
                                    addButton.click(function() {
                                                var element = {};
                                                var commit = $('#brand_grid_edit').jqxGrid('addrow', null, element);
                                    deleteButton.click(function() {
                                        var selectedrowindex = $("#brand_grid_edit").jqxGrid('getselectedrowindex');
                                        var rowscount = $("#brand_grid_edit").jqxGrid('getrows');
                                        if (selectedrowindex >= 0 && selectedrowindex < rowscount.length) {
                                            var id = $("#brand_grid_edit").jqxGrid('getrowid', selectedrowindex);
                                            var commit = $("#brand_grid_edit").jqxGrid('deleterow', id);
                                    {text: 'Advertiser ID', width: 200, datafield: 'advertiserId'},
                                    {text: 'Advertiser Name', width: 300, datafield: 'advertiserName'}
    $('#brand_id_ok').click(function() {
                            var rows = $('#brand_data').jqxGrid('getselectedrowindexes');
                            if (rows.length > 0) {
                                var brand_id = $('#brand_data').jqxGrid('getcellvalue', rows, 'brandId');
                                var result = $.ajax({type: "GET", data: "brand_id=" + brand_id, url: "getAdvertiserByID", async: false}).responseText;
                                var temp = result.split("^");
                                for (var i = 0; i < temp.length; i++) {
                                    var data = temp[i].split(":");
                                    var commit = $('#brand_grid_edit').jqxGrid('addrow', null, {});
                                    $('#brand_grid_edit').jqxGrid('setcellvalue', i, 'advertiserId', data[0]);
                                    $('#brand_grid_edit').jqxGrid('setcellvalue', i, 'advertiserName', data[1]);
    while i set values in grid using setcellvalue method, i got error. Could you please help me where i made mistakes
    Hello selva,
    The error most probably originates from these lines:
    It may be that result is not actually set (the Ajax call fails for some reason). Then temp is undefined, too. This means, when you call temp.length in the for loop, you get “Cannot read property ‘length’ of undefined”.
    selva
    Hi Dimitar,
    I checked that using alert() function.If i removed this below code,
    for example if temp.length is equvalent to 2,two empty row was generated successfully.
