jQuery UI Widgets Forums Navigation NavigationBar, ToolBar, NavBar Toolbar with multi DropDownList
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 8 years, 4 months ago.
  • Toolbar with multi DropDownList #89573
    MickSystematic
    Hi
    I found a bug, when having a multi select DropDownList inside a Toolbar.
    See this fiddle http://jsfiddle.net/Lf3wrycj/3/
    Try and select an option. Now make the window smaller so that the burger menu appears. Open the DropDownList from the burger menu and see that your selection did not work for the “burger” version of the DropDownList.
    We just upgraded jQX in the hopes you would have solved these kinds of problems. Right now I made my own hack to update the burger DropDownList, but it should really work out of the box.
    Kind regards,
    Mick
    Toolbar with multi DropDownList #89588
    Hi Mick,
    Thank you for your feedback. A fix for this issue will hopefully be available in the next version of jQWidgets.
