jQuery UI Widgets Forums Grid Toolbar Filter Problem
This topic contains 2 replies, has 2 voices, and was last updated by  silviorp 10 years, 9 months ago.
  • Toolbar Filter Problem #56880
    silviorp
    Hi.
    I’m trying to change the column being filtered on the toolbar example but it simply don’t work.
    http://jsfiddle.net/jqwidgets/N5qYC/
    In the example this column is being filtered: ( text: ‘City’ datafield: ‘name’ ) and I just can’t put it to work filtering another datafield. What am I doing wrong?
    Toolbar Filter Problem #56883
    Hi silviorp,
    As you can see from the sample, the Grid makes a Server request to a Remote server using the Input’s Value in the query and then re-binds itself depending on the server’s result. That filtering is not built-in the widget. It is available from the Remote server. So, if you want to change that, open geonames.org and look at its available API.
    Toolbar Filter Problem #56884
    silviorp
    Oh, now I understand.
    I’m gonna use Ajax calls for that. I think that’s gonna work, then.
    Thanks.
