jQuery UI Widgets Forums Grid Tabs/Grid Header Spacing Issue
This topic contains 1 reply, has 2 voices, and was last updated by  Stanislav 7 years, 7 months ago.
  • Tabs/Grid Header Spacing Issue #95889
    iLoveJQWidgets
    I have successfully implemented jqxgrids inside jqxtabs in the past but for some reason today I tried again and I am getting some weird spacing between the header and the grid. See the highlight in the screenshot below:
    TAB ERROR
    I’m not using any custom css to override the styling. Even with no grids inside the tabs I still get that space after the header.
    Any idea what’s causing this issue?
    ASPX:
    <div id='jqxTabs'>
            <ul>
                <li style="margin-left: 30px;">
                    Tab 1
                </li>
                <li>
                    Tab 2
                </li>
            </ul>
                <div id="Grid1"></div>
                <p>
                    <!-- Publish button opens dialog that allows user to set scheduled date for publishing changes -->
                    <input id="btn1"  type="button" value="Ignore All" />
                    <!-- Cancel button opens dialog that allows user to go back to Step 1 (Upload Spreadsheet) -->
                    <input id="btn2"  type="button" value="Protect All" />
                    <input id="btn3"  type="button" value="Delete All" />
                    <input id="btn4" type="button" value="Execute" />
                </p>
                <div style="border:none;" id="Grid2"></div>
    Tabs/Grid Header Spacing Issue #95898
    Stanislav
    Hello iLoveJQWidgets,
    It seems that the header isn’t filling the whole space, you can change the padding-bottom and fill it out.
    .jqx-tabs-header {
        padding-bottom: 3px;
    the padding may vary, it depends on how much space there is.
    Stanislav
