jQuery UI Widgets Forums Lists ComboBox Strange behaviour with two combo boxes
This topic contains 3 replies, has 2 voices, and was last updated by  ivailo 9 years, 4 months ago.
  • Strange behaviour with two combo boxes #79026
    GregoryHouseMD
    Here is the scenario:
    I have two cascading combo boxes and I populate them without a problem. I have two different keyUp event handlers on both of them when enter is pressed. Once I make the selection on the first combo box, the keyup event for the first combo box is caught, the second combo gets populated, and I set the focus on the second combo box.
    Now, if I start typing, autocomplete kicks in on the second combo box and I can move up and down the items, if I hit enter the proper code is run.
    Here is the strange part. Once the focus is moved to the second combo box, if I don’t type anything but go trough the items using the arrows only, the popup doesn’t open (and it shouldn’t right?) and when I get to the item I want, if I hit enter, the keyup on the first element gets fired…
    Any ideas or workarounds?
    Strange behaviour with two combo boxes #79039
    ivailo
    Hi GregoryHouseMD,
    Please send a fiddle/jseditor link with your code for analyze.
    Ivailo Ivanov
    Strange behaviour with two combo boxes #79053
    GregoryHouseMD
    This is the javascript I’m using, a bit striped down, caust it has a lot of stuff going on: jsEditor
    Strange behaviour with two combo boxes #79117
    ivailo
    Hi GregoryHouseMD,
    From this part of code is dificult to be analyzed the behavior you talk about.
    Please modify the example to be working and demonstrating the problematic behavior.
    Also you can see our cascading combo boxes demo.
    Ivailo Ivanov
