jQuery UI Widgets Forums Navigation Tabs Start with tabs collapsed
This topic contains 1 reply, has 2 voices, and was last updated by  Martin 4 years, 5 months ago.
  • Start with tabs collapsed #113665
    ajcs
    I am using jqxTabs and there is a situation where I want to start with the tabs collapsed. In the $(document).ready function if I call the collapse method I get the following error:
    Cannot read property ‘style’ of null
    Is there a way to start with the tabs collapsed?
    Start with tabs collapsed #113666
    Martin
    Hello ajcs,
    It seems that you call the collapse method before the tabs are created.
    Please, take a look at the following Example.
    Martin Yotov
    https://www.jqwidgets.com
