jQuery UI Widgets › Forums › Chart › Stacked Column Cart with JSON Data Input
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 11 years, 9 months ago.
Hello Fellows,
i have a problem integrating hierarchical data in JSON format into a stacked column chart.
My code:var data = ‘[{“time”:20,”data”:[{“Service”:”service_a”,”count”:22},{“Service”:”service_b”,”count”:2}]},{“time”:21,”data”:[{“Service”:”service_a”,”count”:17}]},{“time”:22,”data”:[{“Service”:”service_a”,”count”:22}]},{“time”:23,”data”:[{“Service”:”service_a”,”count”:9}]}]’;
{ name: “time”, type : ‘int’},
{ name: “Service”, map : “data>Service”, type : ‘string’ },
{ name: “count”, map : “data>count”, type : ‘int’ }
localdata: data
var dataAdapter = new $.jqx.dataAdapter(source);var settings = {
title: “Hits-Scorecard”,
description: “Number of funtioncalls per hour”,
titlePadding: { left: 0, top: 0, right: 0, bottom: 10 },
showBorderLine: false,
categoryAxis:
dataField: ‘hour’,
showGridLines: false
colorScheme: ‘myScheme’,
seriesGroups:
type: ‘stackedcolumn’,
columnsGapPercent: 30,
seriesGapPercent: 0,
valueAxis:
unitInterval: 25,
description: ‘Hits per hour’
series: [
dataField: ‘count’,
displayText: ‘Service’
};$(‘#hitsChart’).jqxChart(settings);
The Chart is rendered but without data. I don’t know, where my Errors are. May somebody help me?
In the final application, the json-data will be load from a webservice via a php-proxy.Thx a lot!
Hello Keule,
The issue comes from the data source. Instead of:
var data = ‘[{"time":20,"data":[{"Service":"service_a","count":22},{"Service":"service_b","count":2}]},{“time”:21,”data”:[{"Service":"service_a","count":17}]},{“time”:22,”data”:[{"Service":"service_a","count":22}]},{“time”:23,”data”:[{"Service":"service_a","count":9}]}]’;
you should have:
var data = [{ "time": 20, "data": { "Service": "service_a", "count": 22} }, { "time": 21, "data": { "Service": "service_a", "count": 17} }, { "time": 22, "data": { "Service": "service_a", "count": 22} }, { "time": 23, "data": { "Service": "service_a", "count": 9}}];
However, in the latter case, note that you cannot have two “Service” fields in one data item.
