I was hoping to format the spacing between columns on my stacked and grouped column chart – but changing the column and series spacing and min/max column size settings does not seem to have any impact on it. It does if I un-stack the columns. Is this supposed to work?
… And to follow up with that.. We wanted to have a legend at the bottom of the chart, but the legend is showing each and every series… I would need it to show perhaps only the first 5 of the series (since each subsequent set of 5 series will be the same color).. And if I could get it to do that, I would need custom labels for those first 5 series … Is this possible?
Thanks in advance,
