jQuery UI Widgets Forums Grid SQL Statement for Grid Contens
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 10 years, 5 months ago.
  • SQL Statement for Grid Contens #62614
    derarnold
    Hello hello.
    For the export I have written manually, I need to know the status of the filters of my main grid as well as the displayed columns.
    Is there any way to get the parameters, that the grid is sending to the php backend?
    Has anyone perhaps a sample code?
    Thank you
    Oliver
    SQL Statement for Grid Contens #62645
    Hello Oliver,
    You can get the status of the filters with the method getfilterinformation. You can also iterate through all the columns and check which ones are visible with the method iscolumnvisible.
