jQuery UI Widgets Forums Layouts Splitter Splitter with ListBox inside
This topic contains 4 replies, has 2 voices, and was last updated by  Ivo Zhulev 8 years, 6 months ago.
  • Splitter with ListBox inside #88159
    Pfhoenix
    I have a splitter with a listbox filling one of the panels. If I set the listbox to 100% height and margin-top of 5px, it looks correct… until I select an item in the listbox, where the listbox then jumps to fill the entire panel. Is this a bug within Splitter or ListBox? I have a jsfiddle that demonstrates the bug :
    The jumping happens whether margin is set, padding is set, a spacer div is placed above the listbox; I’ve spent a full day trying to figure this out, and at this point, I’m convinced it’s a bug within either Splitter or ListBox
    Splitter with ListBox inside #88167
    Pfhoenix
    The link didn’t make it into the post for some reason.
    jsfiddle reproduction case
    Splitter with ListBox inside #88187
    Ivo Zhulev
    Hi Pfhoenix,
    What are you trying to achieve?
    Ivo
    Splitter with ListBox inside #88211
    Pfhoenix
    A listbox that doesn’t move itself within a splitter panel? Your response confuses me, due to the clarity in which I presented the issue and a reproduction case/link.
    Here’s another test case, with the jumping removed : http://jsfiddle.net/Pfhoenix/az4y0ekb/3/
    What’s interesting is that even setting the height for the listbox doesn’t stop it from moving up by the total height of its border. With its border hidden and a set height, the listbox no longer moves itself. This indicates to me that the bug is clearly within listbox and not splitter.
    Splitter with ListBox inside #88224
    Ivo Zhulev
    Hi Pfhoenix,
    Thanks for the feedback, we will look into this.
    Ivo
