jQuery UI Widgets Forums Layouts Splitter Splitter issue inside tabs
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 11 years, 8 months ago.
  • Splitter issue inside tabs #26790
    rskbuvan
    Spectator
    I’ve 3 tabs in my application, where each tab has jqxSplitter (i.e. Left side has Grid & Right side has its respective details, which will open upon onclick on grid rows) and it is in collapsed state by default.
    Without expanding any of the splitter, I’m navigation to each tab. When I’m coming back to any of the tab, the collapsed splitter has got expanded by default.
    For Example:
    1) I’m visiting Tab 1 and Tab 2 – without expanding the splitter.
    2) Now I’m coming back to Tab 1, now the collapsed splitter has got expanded.
    Note: Each splitter has unique ID
    Can anyone suggest me, what could be the possible cause and how to prevent this?
    Hope I explained it clearly here.
    Looking for a solution.
    Thanks & Cheers,
    \_rssb
    Splitter issue inside tabs #26861
    Hi rskbuvan,
    Please, provide a sample web page which demonstrates your scenario.
    The following is a sample with Tabs and Splitter. There are 2 Splitter instances within 2 tabs.
    <link rel="stylesheet" href="../../jqwidgets/styles/jqx.bootstrap.css" type="text/css" />
    <script type="text/javascript" src="../../jqwidgets/jqxsplitter.js"></script>
    var theme = "bootstrap";
    $("#tabs").jqxTabs({ theme: theme, height: '100%', width: '100%',
    initTabContent: function (tab) {
    if (tab == 0) {
    $('#splitter').jqxSplitter({ height: '100%', width: '100%', theme: theme, panels: [{ size: '50%'}] });
    else {
    $('#splitter2').jqxSplitter({ orientation: 'horizontal', height: '100%', width: '100%', theme: theme, panels: [{ size: '50%'}] });
    <style>
    html, body {
    width: 100%; height: 100%; overflow: hidden; padding: 0; margin: 0;
    </style>
    <div id="tabs">
    <ul>
    <li style="margin-left: 30px;">Tab 1</li>
    <li>Tab 2</li>
    </ul>
    <div class="jqx-hidescrollbars">
    <div class="jqx-hideborder" id="splitter">
    <div>
    Content 1.1
    <div>
    Content 1.2
    <div class="jqx-hideborder" id="splitter2">
    <div>
    Content 2.1
    <div>
    Content 2.2
    Also make sure that you use the current version – 2.9.3.
