jQuery UI Widgets › Forums › Layouts › Splitter › Splitter in 100% div does not function correctly
This topic contains 3 replies, has 2 voices, and was last updated by Peter Stoev 12 years, 11 months ago.
I have created this test case to illustrate the problem of using a splitter inside a div that adjusts to use the remaining space. This test case raises multiple issues: 1) the splitter assumes a very large width with the div containing jqx-splitter-panel-wrapper set to width: 158332px; 2) the splitter height is also too high, 3) note the placement of the content for the second panel. Please advise.
Vertical Splitter
var theme = ”;
$(‘#mainSplitter’).jqxSplitter({ width: ‘100%’, height: ‘100%’, theme: theme, panels: [{ size: ‘40%’ }, { size: ‘60%’}] });
});html {
height:100%;
width: 100%;
body {
height:100%;
width: 100%;
#container {
height:100%;
width: 100%;
#header {
width: 100%;
height: 44px;
background-color: #333;
#leftTabs {
height: 100%;
width: 44px;
#rightPanel {
height:100%;
width: 100%;
#rightPanelContainer {
height:100%;
#splitterContainer {
height:100%;
width: 100%;
}Panel 1Panel 2I will send you the code via email
We are unable to reproduce the issue with the provided information. Please send us a small sample which will illustrate the problem, so we will be able to test and debug with the specific application scenario.
http://www.jqwidgets.comThank you about the Splitter’s sample and for the feedback.
Here’s the sample’s code:
<!DOCTYPE html><html lang="en"><head><meta name="keywords" content="jQuery Splitter, Splitter Widget, Splitter, jqxSplitter" /><meta name="description" content="This page demonstrates splitter's events" /><title id='Description'>Vertical Splitter</title><link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /><script type="text/javascript" src="../../scripts/jquery-1.7.2.min.js"></script><script type="text/javascript" src="../../scripts/gettheme.js"></script><script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script><script type="text/javascript" src="../../jqwidgets/jqxsplitter.js"></script><script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script><script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script><script type="text/javascript" src="../../jqwidgets/jqxpanel.js"></script><script type="text/javascript"> $(document).ready(function () { var theme = ''; $('#mainSplitter').jqxSplitter({ width: '100%', height: '100%', theme: theme, panels: [{ size: '40%' }, { size: '60%'}] }); }); </script><style type="text/css">html { height:100%; width: 100%;}body { height:100%; width: 100%;}#container { height:100%; width: 100%;}#header { width: 100%; height: 44px; background-color: #333;}#leftTabs { height: 100%; width: 44px; background-color: #333;}#rightPanel { height:100%; width: 100%;}#rightPanelContainer { height:100%;}#splitterContainer { height:100%; width: 100%;}</style></head><body class='default'><table id="container" cellpadding="0" cellspacing="0" border="0" width="100%"> <tr> <td> <table cellpadding="0" cellspacing="0" border="0" width="100%" height="100%"> <tr> <td id="leftTabs" width="44px"><img src="../../images/progress1.jpg" width="47" height="20"></td> </tr> </table> </td> <td id="rightPanel"> <table id="rightPanelContainer" cellpadding="0" cellspacing="0" border="0" width="100%"> <tr> <td id="header"> </td> </tr> <tr> <td id="splitterContainer"> <div id="mainSplitter"> <div class="splitter-panel"> Panel 1</div> <div class="splitter-panel"> Panel 2</div> </div> </td> </tr> </table> </td> </tr></table></body></html>
I was able to reproduce the reported issue and created a new work item about it.
Best Wishes,
