jQuery UI Widgets Forums Grid Sorting and Filtering in Pagination Virtual mode
This topic contains 2 replies, has 3 voices, and was last updated by  reven 6 years, 1 month ago.
  • Gowri
    I would like to do sorting and filtering in pagination virtual mode. I found few samples were those sorting and filtering is happening on server side, but I would like to do in client side. i.e The record which is available in current page, I have to apply sorting and filtering.
    Example: I have grid with pagination virtual mode and total row count is 1000 and page count is 100. I would like to sort and filter on those 100 records in current page rather than 1000 records in server.
    Thanks in Advance.
    Gowri.
    Hi Gowri,
    Unfortunately, only server-side sorting and filtering can be used when virtual mode is enabled. There is no client-side solution.
    reven
    This doesnt appear to be true. I managed to get this working via
          let rowData = null;
          this.jqxGrid.rendergridrows((obj) => {
            rowData = obj.data;
            return obj.data;
          this.jqxGrid.onSort.subscribe((event) => {
            const col = event.args.sortinformation.sortcolumn;
            const descending = event.args.sortinformation.sortdirection.descending === true;
            rowData.sort((a, b) => {
              if (a[col] > b[col])
                return descending ? -1 : 1;
              else if (a[col] < b[col])
                return descending ? 1 : -1;
              return 0;
    This may have changed in the last 3 years. But this appears to be working for me.
