jQuery UI Widgets Forums Grid Sort order not working for ‘localdata’
This topic contains 2 replies, has 2 voices, and was last updated by  aravindtrue 12 years, 4 months ago.
  • Sort order not working for ‘localdata’ #11873
    aravindtrue
    For some reason, I am loading the plugin into two half, please have a look at the below code. The sort is not working, but When I comment the ‘localdata’ and uncomment the ‘url’, it works perfect. I am not getting the problem, why it is not working for ‘localdata’.
        <title id='Description'>This example shows how to create a Grid from JSON data.</title>
        <script type="text/javascript" src="../../scripts/jquery-1.8.1.min.js"></script>
    	<script type="text/javascript" src="../../jqwidgets/jqxnumberinput.js"></script>
    		var theme = getTheme();
    		var url = "../sampledata/beverages.txt";
    		$("#jqxgrid").jqxGrid({
    			width: '100%',
    			pagesize: 200,
    			pagesizeoptions: ['10', '50', '100', '200'],
    			autoshowfiltericon: true,
    			altrows: true,
    			selectionmode: 'singlerow',
    			editmode: 'dblclick'
    		var source = {
    			  { name: 'name' },
    			  { name: 'type' },
    			  { name: 'calories', map: 'calories>old', type: 'integer'},
    			  { name: 'totalfat' },
    			  { name: 'protein' },
    			localdata: [{"id": "1",
    					"name": "Hot Chocolate",
    					"type": "Chocolate Beverage",
    					"calories": "370",
    					"totalfat": "16g",
    					"protein": "14g"
    					"id": "2",
    					"name": "Peppermint Hot Chocolate",
    					"calories": "440",
    					"totalfat": "16g",
    					"protein": "13g"
    					"id": "3",
    					"name": "Salted Caramel Hot Chocolate",
    					"calories": "450",
    					"totalfat": "16g",
    					"protein": "13g"
    			/*url: url,*/
    			sortcolumn: 'name',
    			sortdirection: 'asc'
    				selectedrowindex: 0,
    				  { text: 'Name', datafield: 'name'},
    				  { text: 'Beverage Type', datafield: 'type'},
    				  { text: 'Calories', datafield: 'calories', cellsformat: 'c2',
                                       columntype: 'numberinput' },
    		                  { text: 'Total Fat', datafield: 'totalfat' },
    				  { text: 'Protein', datafield: 'protein' }
        <div id='jqxWidget' style="font-size: 13px; font-family: Verdana; float: left; width:80%;">
    		<div id="jqxgrid"></div>
    Please help me on this.
    Aravind M S
    Sort order not working for ‘localdata’ #11884
    Hi Aravind.
    The posted code works fine with jQWidgets 2.5.5 on my side. The first column is sorted by default as you specified in the source object’s initialization and the sorting for the other columns works, too.
    aravindtrue
    Thanks a lot. I’ll update the jQwidgets version.
    Aravind
