I am trying to use the everpresentrow to add/update a record, By having a pull down grid they can chose a record and have multiple fields populated. For instance if a user is entering multiple items into a purchase order. They would lookup to the item in the grid, select that item and the system would fill the everpresentrow with the item #,Description,the Last Purchase Prices etc. The user could then edit some fields and add the record. I semi have it working by using a seteverpresentrowwidgetvalue method, but I’m not sure if I should be using this method.
Any suggestions would be greatly appreciated.
Louis
