jQuery UI Widgets Forums Grid Setting calendar culture inside grid
This topic contains 6 replies, has 2 voices, and was last updated by  alexz 12 years, 5 months ago.
  • Setting calendar culture inside grid #11521
    alexz
    Hi, how can I set culture for calendar that is inside grid (columntype: ‘datetimeinput’)?
    When trying to figure it out myself, I found a strange line of code inside jqxcalendar:
    a.global.preferCulture(this.culture);
    Why calendar is trying to set own culture globally? At the beginning of my page I have following line of code and I expect that setting not to be changed:
    jQuery.global.preferCulture('fi-FI');
    Any help appreciated,
    BR, Alex.
    Setting calendar culture inside grid #11522
    Hi Alex,
    The calendar sets a culture depending on its ‘culture’ property. You can set a culture in the createeditor function.
    Setting calendar culture inside grid #11528
    alexz
    Thanks for prompt reply, now I added following functions (initeditor added after no success with createeditor):
    createeditor:function (row, value, editor) { editor.jqxCalendar({ culture: 'fi-FI' }); }, initeditor:function (row, value, editor) { editor.jqxCalendar({ culture: 'fi-FI' }); }
    but with no success, tried also to remove
    columntype: 'datetimeinput'
    but then column has just textbox editor.
    Setting calendar culture inside grid #11530
    alexz
    Do I have to set also formatString of jqxdatetimeinput?
    Setting calendar culture inside grid #11532
    Hi Alex,
    The editor used in the Grid is jqxDateTimeInput, not jqxCalendar.
    Setting calendar culture inside grid #11534
    alexz
    Thanks Peter, now works like a charm!
    Setting calendar culture inside grid #11545
    alexz
    Unfortunately still have a problem, calendar comes localized, but date is in default culture format, like 11.27.2012, should be 27.12.2012
    createeditor:function (row, value, editor) { editor.jqxDateTimeInput({ culture: 'fi-FI' }); }
