jQuery UI Widgets › Forums › Grid › Set a default label for blank filter?
This topic contains 2 replies, has 2 voices, and was last updated by stan92 10 years, 7 months ago.
is it possible to add a default label when an item of a filtered dropdownlist is empty or blank ?
Something like “not set” ?Hi stan92,
With a small customization and implementing the “createfilterwidget” method you can achieve that.
Example:
<!DOCTYPE html> <html lang="en"> <head> <title id='Description'>This example illustrates the Grid filtering feature. Enter some data into the Filter Row.</title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.10.2.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.filter.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.sort.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcalendar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdatetimeinput.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="../../jqwidgets/globalization/globalize.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript" src="generatedata.js"></script> <script type="text/javascript"> $(document).ready(function () { var data = generatedata(500); data[0].productname = ""; var source = { localdata: data, datafields: [ { name: 'name', type: 'string' }, { name: 'productname', type: 'string' }, { name: 'available', type: 'bool' }, { name: 'date', type: 'date'}, { name: 'quantity', type: 'number' } ], datatype: "array" }; var dataAdapter = new $.jqx.dataAdapter(source); $("#jqxgrid").jqxGrid( { width: 850, source: dataAdapter, showfilterrow: true, filterable: true, selectionmode: 'multiplecellsextended', columns: [ { text: 'Name', columntype: 'textbox', filtertype: 'input', filtercondition: 'starts_with', datafield: 'name', width: 215 }, { text: 'Product', filtertype: 'checkedlist', datafield: 'productname', width: 220, createfilterwidget: function (column, element, widget) { $(widget).jqxDropDownList('emptyString', 'not set'); } }, { text: 'Available', datafield: 'available', columntype: 'checkbox', filtertype: 'bool', width: 67 }, { text: 'Ship Date', datafield: 'date', filtertype: 'range', width: 210, cellsalign: 'right', cellsformat: 'd' }, { text: 'Qty.', datafield: 'quantity', filtertype: 'number', cellsalign: 'right' } ] }); $('#clearfilteringbutton').jqxButton({ height: 25}); $('#clearfilteringbutton').click(function () { $("#jqxgrid").jqxGrid('clearfilters'); }); }); </script> </head> <body class='default'> <div id="jqxgrid"> </div> <input style="margin-top: 10px;" value="Remove Filter" id="clearfilteringbutton" type="button" /> </body> </html>
http://www.jqwidgets.comWorks like a charm.. I thank you…
