jQuery UI Widgets › Forums › Angular › ServerSide pagination using observable pattern
Tagged: Angular, angular treegrid, observable, pagination server side
This topic contains 5 replies, has 2 voices, and was last updated by Peter Stoev 7 years, 7 months ago.
Hi Team,
I am binding the treeGrid data with angular observable call to backend which is groovy on grails, Can you please provide me with an example on how to update source with total records and pass pagination params. Kindly do the needful.
SandeepHi, Below is my component code, i Need to set the total records to source on data response but it’s not setting with this.source.totalrecords method and the total records will be 20(this.source.totalrecords = 20) and pagination buttons will be disabled, i cannot call for next set of records.
import {Component, ViewChild, OnInit, AfterViewInit} from ‘@angular/core’;
import {jqxTreeGridComponent} from ‘jqwidgets-framework/jqwidgets-ts/angular_jqxtreegrid’;
import {jqxLoaderComponent} from ‘jqwidgets-framework/jqwidgets-ts/angular_jqxloader’;
import {DashboardService} from ‘./dashboard.service’
import * as _ from ‘underscore’;
declare var jquery: any;
declare var $: any@Component({
selector: ‘app-dashboard’,
templateUrl: ‘./dashboard.component.html’,
styleUrls: [‘./dashboard.component.css’]
export class DashboardComponent implements AfterViewInit {constructor(private dashboardService: DashboardService) {
}@ViewChild(‘treeGridReference’) treeGrid: jqxTreeGridComponent;
@ViewChild(‘jqxLoader’) jqxLoader: jqxLoaderComponent;
pagtiationParams:any = {}
currentRow: any = {}
productFamilyList:any = []
ngAfterViewInit(): void {
this.jqxLoader.open();
this.pagtiationParams = {offset: 0, limit: this.treeGridSettings.pageSize}
this.fetchGridData(this.pagtiationParams);
}_lockedRows: any [];
newRowID = null;
theme: string = ”;
buttonsObject: any = null;
newProductFamily : any = {}
editSettings: any = {
saveOnPageChange: false,
saveOnBlur: false,
saveOnSelectionChange: false,
cancelOnEsc: true, saveOnEnter: false,
editOnDoubleClick: false, editOnF2: false
}source: any =
dataType: ‘array’,
dataFields: [
{name: ‘id’, type: ‘number’},
{name: ‘parentId’, type: ‘number’},
{name: ‘pfId’, type: ‘number’},
// Customer Section Data fields
{name: ‘aggregatedCustomer’, type: ‘string’},
{name: ‘salesRegion’, type: ‘string’},
{name: ‘subBusinessEntity’, type: ‘string’},// SFDC Section Data fields
{name: ‘finBookingsActuals’, type: ‘number’},
{name: ‘sfdcCommit’, type: ‘number’},
{name: ‘sfdcWeekByWeekActuals’, type: ‘number’},
{name: ‘sfdcActualsPlusCommit’, type: ‘number’},
{name: ‘sfdcUpside’, type: ‘number’},// Forecast and actuals Section Data fields
{name: ‘fy11’, type: ‘number’},
{name: ‘fy12’, type: ‘number’},
{name: ‘fy13’, type: ‘number’},
{name: ‘fy14’, type: ‘number’},
{name: ‘fy21’, type: ‘number’},
{name: ‘fy22’, type: ‘number’},
{name: ‘fy23’, type: ‘number’},
{name: ‘fy24’, type: ‘number’},// Product family Section Data fields
{name: ‘productManager’, type: ‘string’},
{name: ‘productFamily’, type: ‘string’},
{name: ‘pmBottomsUp’, type: ‘number’},
{name: ‘pmRisk’, type: ‘number’},
{name: ‘pmUpside’, type: ‘number’},
{name: ‘pmProbability’, type: ‘number’},
{name: ‘pmEstimatedQ1FyForecast’, type: ‘number’},
{name: ‘pmEstimatedQ2FyForecast’, type: ‘number’},
{name: ‘pmEstimatedQ3FyForecast’, type: ‘number’},
{name: ‘pmEstimatedQ4FyForecast’, type: ‘number’},
{name: ‘pmComments’, type: ‘string’},
{name: ‘pmTimeStamp’, type: ‘string’},// Business Analyst Section Data fields
{name: ‘baCurrentSalesForecast’, type: ‘number’},
{name: ‘baBottomsUp’, type: ‘number’},
{name: ‘baRisk’, type: ‘number’},
{name: ‘baUpside’, type: ‘number’},
{name: ‘baProbability’, type: ‘number’},
{name: ‘criticalDeal’, type: ‘string’},
{name: ‘baStatus’, type: ‘string’},
{name: ‘baComments’, type: ‘string’},
{name: ‘baExecutiveSummary’, type: ‘string’}
],hierarchy: {
keyDataField: {name: ‘id’},
parentDataField: {name: ‘parentId’}
url:this.fetchGridData(this.pagtiationParams),
addRow: (rowID, rowData, position, parentID, commit) => {
this.newRowID = rowID;
console.log(rowData);
console.log(“test add”);
console.log(this.newProductFamily);
//console.log(rowData);
this.dashboardService.saveDft(this.newProductFamily)
.subscribe(
result => {
console.log(“backend data”);
console.log(result);
this.newProductFamily.pfId = result.id;
commit(true,result.id);
//error => this.errorMessage = <any>error
updateRow: (rowID, rowData, commit) => {
rowData[‘parent’] = null;
if(rowData[‘pfId’] == null) {
rowData[‘pfId’] = this.newProductFamily.pfId;
this.dashboardService.updateDft(rowData)
.subscribe(
result => {
commit(true);
deleteRow: (rowID, rowData, commit) => {
console.log(rowID);
let deleteObject = this.treeGrid.getRow(rowID);
deleteObject[‘parent’] = null;
if(deleteObject[‘pfId’] == null) {
deleteObject[‘pfId’] = this.newProductFamily.pfId;
this.dashboardService.deleteDft(deleteObject)
.subscribe(
result => {
console.log(this.currentRow[‘rowKey’]);
this.treeGrid.updateBoundData();
commit(true);
};dataAdapter: any = new jqx.dataAdapter(this.source);
treeGridSettings: jqwidgets.TreeGridOptions =
height: “auto”,
width: ‘100%’,
source: this.dataAdapter,
pageSize: 200,
//pageable: true,
//columnsResize: true,
ready: (): void => {
var grid: any = this.treeGrid;
_.each(this._lockedRows, function (lockedRow) {
grid.lockRow(lockedRow);
text: ‘Customer’,
dataField: ‘aggregatedCustomer’,
width: 275,
editable: false,
columnType: ‘template’,
cellsalign: ‘left’,
align: ‘center’,
pinned: true,
createEditor: (row, cellvalue, editor, cellText, width, height) => {
//construct the editor.
let source = this.productFamilyList;
editor.jqxDropDownList({
autoDropDownHeight: true,
source: source,
width: ‘100%’,
height: ‘100%’
initEditor: (row, cellvalue, editor, celltext, width, height) => {
// set the editor’s current value. The callback is called each time the editor is displayed.
editor.jqxDropDownList(‘selectItem’, cellvalue);
getEditorValue: (row, cellvalue, editor) => {
// return the editor’s value.
return editor.val();
text: ‘Sales Region’,
dataField: ‘salesRegion’,
width: 120,
editable: false,
//columnType: ‘none’,
cellsalign: ‘left’, align: ‘center’,
pinned: true
text: ‘Sub Business Entity’,
dataField: ‘subBusinessEntity’,
width: 140,
editable: false,
pinned: true
},// SFDC Section Columns
text: ‘SFDC Wk Actuals’,
dataField: ‘finBookingsActuals’,
width: 120,
editable: false,
cellsalign: ‘right’,
align: ‘center’,
columnType: ‘none’,
cellsFormat: ‘c’,
text: ‘SFDC Wk Commit’,
dataField: ‘sfdcCommit’,
width: 120,
editable: false,
align: ‘center’,
columnType: ‘none’,
cellsFormat: ‘c’,
text: ‘Wk/ Wk Commit’,
dataField: ‘sfdcWeekByWeekActuals’,
width: 120,
editable: false,
columnType: ‘none’,
cellsalign: ‘right’, align: ‘center’,
cellsFormat: ‘c’,
text: ‘SFDC Wk Act + Commit’,
dataField: ‘sfdcActualsPlusCommit’,
width: 140,
editable: false,
columnType: ‘none’,
cellsFormat: ‘c’,
text: ‘SFDC Wk Upside’, dataField: ‘sfdcUpside’, width: 120, editable: false,
columnType: ‘none’, cellsalign: ‘right’, align: ‘center’, cellsFormat: ‘c’,
},// Actuals and Forecast Section Columns
text: ‘Bookings Q1-FY16 A’,
dataField: ‘fy11’,
width: 120,
columnType: ‘none’,
editable: false,
cellsAlign: ‘right’,
align: ‘center’,
cellsFormat: ‘c’,
text: ‘Bookings Q2-FY16 A’,
dataField: ‘fy12’,
columnType: ‘none’,
width: 120, cellsalign: ‘right’, align: ‘center’,
editable: false,
cellsFormat: ‘c’,},
text: ‘Bookings Q3-FY16 A’,
dataField: ‘fy13’,
columnType: ‘none’,
editable: false,
cellsFormat: ‘c’,
text: ‘Bookings Q4-FY16 A’,
dataField: ‘fy14’,
columnType: ‘none’,
editable: false,
cellsFormat: ‘c’,
text: ‘Bookings Q1-FY17 A’,
dataField: ‘fy21’,
columnType: ‘none’,
editable: false, cellsFormat: ‘c’,
text: ‘Bookings Q2-FY17 A’,
dataField: ‘fy22’,
columnType: ‘none’,
text: ‘Bookings Q3-FY17 A’,
dataField: ‘fy23’,
columnType: ‘none’,
text: ‘Bookings Q4-FY17 A’,
dataField: ‘fy24’,
columnType: ‘none’,
},// Product Manager Section Columns
text: ‘Product Manager’,
dataField: ‘productManager’,
columnType: ‘none’,
editable: false,
text: ‘Product Family’,
dataField: ‘productFamily’,
width: 150,
align: ‘center’,
source: source,
width: ‘100%’,
height: ‘100%’
text: ‘PM Bottoms Up’,
cellsFormat: ‘c’,
dataField: ‘pmBottomsUp’,
text: ‘PM Risk’,
dataField: ‘pmRisk’,
cellsAlign: ‘center’,
width: 120,
cellsFormat: ‘c’,
text: ‘PM Upside’,
dataField: ‘pmUpside’,
editable: true, cellsFormat: ‘c’,
text: ‘PM Probability’,
dataField: ‘pmProbability’,
width: 150,
cellsalign: ‘center’,
align: ‘center’,
// construct the editor.
let source = [‘10%’, ‘25%’, ‘50%’, ‘75%’, ‘100%’];
filterable:true,
source: source,
width: ‘100%’,
height: ‘100%’,
text: ‘PM Est. Q1FY18 F’,
dataField: ‘pmEstimatedQ1FyForecast’,
text: ‘PM Est. Q2FY18 F’,
dataField: ‘q2FY18 F’,
text: ‘PM Est. Q3FY18 F’,
dataField: ‘pmEstimatedQ3FyForecast’,
text: ‘PM Est. Q4FY18 F’,
dataField: ‘pmEstimatedQ4FyForecast’,
text: ‘PM Comments’,
dataField: ‘pmComments’,
text: ‘Timestamp’,
dataField: ‘pmTimeStamp’,
editable: true
},// Business Analyst Section Columns
text: ‘Current Sales Forecast’,
dataField: ‘baCurrentSalesForecast’,
text: ‘BA Bottoms up’,
dataField: ‘baBottomsUp’,
text: ‘BA Risk’,
dataField: ‘baRisk’,
width: 120,
align: ‘center’,
text: ‘BA Upside’,
dataField: ‘baUpside’,
text: ‘BA Probability’,
dataField: ‘baProbability’,
width: 150,
align: ‘center’,
source: source,
width: ‘100%’,
height: ‘100%’
text: ‘Critical Deal’,
dataField: ‘criticalDeal’,
width: 100,
align: ‘center’,
let source = [‘Yes’, ‘No’];
source: source,
width: ‘100%’,
height: ‘100%’
text: ‘BA Status’,
dataField: ‘status’,
width: 150,
cellsalign: ‘left’,
align: ‘center’,
let source = [‘OPPORTUNITY’, ‘POC’, ‘WON’, ‘LOST’];
source: source,
width: ‘100%’,
height: ‘100%’
text: ‘BA Comments’,
dataField: ‘baComments’,
width: 300, cellsalign: ‘left’, align: ‘center’,
editable: true
text: ‘BA Executive Summary’,
dataField: ‘baExecutiveSummary’,
width: 300, cellsalign: ‘center’, align: ‘center’,
editable: true
};checkBoxChange(event: any): void {
this.showHideColumns(event);
}private showHideColumns(event: any) {
this.treeGrid.beginUpdate();
if (event.args.checked) {
this.treeGrid.hideColumn(‘fy11’)
this.treeGrid.hideColumn(‘fy12’)
this.treeGrid.hideColumn(‘fy13’)
this.treeGrid.hideColumn(‘fy14’)
this.treeGrid.hideColumn(‘fy21’)
this.treeGrid.hideColumn(‘fy22’)
this.treeGrid.hideColumn(‘fy23’)
this.treeGrid.hideColumn(‘fy24’)
else {
this.treeGrid.showColumn(‘fy11’)
this.treeGrid.showColumn(‘fy12’)
this.treeGrid.showColumn(‘fy13’)
this.treeGrid.showColumn(‘fy14’)
this.treeGrid.showColumn(‘fy21’)
this.treeGrid.showColumn(‘fy22’)
this.treeGrid.showColumn(‘fy23’)
this.treeGrid.showColumn(‘fy24’)
this.treeGrid.endUpdate();
}fetchGridData(paginationParams: any): void {
this.dashboardService.getDashboardData(paginationParams).subscribe(res => {var responseData = res.data;
var parentRows: any [] = [];
var uniqCustomers = _.uniq(_.pluck(responseData, ‘aggregatedCustomer’));_.each(uniqCustomers, function (customerName) {
// fetch customer records
var customerRecords: any[] = _.where(responseData, {‘aggregatedCustomer’: customerName});//iterate and assign the parentId
var parentId: any;
_.each(customerRecords, function (customer: any) {
if (customer.aggregatedCustomer !== null && customer.subBusinessEntity !== null && customer.productFamily !== null) {
parentId = _.filter(customerRecords, function (customerRecord) {
if (!customerRecord.productFamily && customerRecord.subBusinessEntity == customer.subBusinessEntity)
return customerRecord
})[0].id
customer[“parentId”] = parentId;
parentRows.push(parentId);
} else if (customer.aggregatedCustomer !== null && customer.subBusinessEntity !== null) {
if (customer.productFamily == null) {
if (!customerRecord.productFamily && !customerRecord.subBusinessEntity)
})[0].id
parentRows.push(customer.id)
else {
customer[“parentId”] = null
this.createAndLoadGrid(responseData, res.FiscalYearMapping, parentRows);
}private createAndLoadGrid(responseData: any, columnNames: any, parentRows: any[]) {
this.source.totalrecords = 20;
this.source.localData = responseData;
this._lockedRows = _.uniq(parentRows);
console.log(“parent row”);
console.log(this._lockedRows);
this.jqxLoader.close();
this.treeGrid.createComponent(this.treeGridSettings);
this.treeGrid.setColumnProperty(‘fy11’, ‘text’, columnNames.fy11);
this.treeGrid.setColumnProperty(‘fy12’, ‘text’, columnNames.fy12);
this.treeGrid.setColumnProperty(‘fy13’, ‘text’, columnNames.fy13);
this.treeGrid.setColumnProperty(‘fy14’, ‘text’, columnNames.fy14);
this.treeGrid.setColumnProperty(‘fy21’, ‘text’, columnNames.fy21);
this.treeGrid.setColumnProperty(‘fy22’, ‘text’, columnNames.fy22);
this.treeGrid.setColumnProperty(‘fy23’, ‘text’, columnNames.fy22);
this.treeGrid.setColumnProperty(‘fy24’, ‘text’, columnNames.fy23);
}updateButtons(action: string, rowData: any, buttons: any): void {
switch (action) {
case ‘Select’:
if (rowData[‘aggregatedCustomer’] && rowData[‘subBusinessEntity’]) {
if (!rowData[‘productFamily’]) {
buttons.addPFButton.jqxButton({disabled: false});
}else {
buttons.deletePFButton.jqxButton({ disabled: false });
if (rowData[‘aggregatedCustomer’] && !rowData[‘subBusinessEntity’]) {
buttons.addOpportunityButton.jqxButton({disabled: false});
buttons.editButton.jqxButton({disabled: false});
buttons.cancelButton.jqxButton({disabled: true});
buttons.updateButton.jqxButton({disabled: true});
break;
case ‘Unselect’:
buttons.addPFButton.jqxButton({disabled: true});
buttons.addOpportunityButton.jqxButton({disabled: true});
buttons.editButton.jqxButton({disabled: true});
break;
case ‘Edit’:
buttons.deletePFButton.jqxButton({ disabled: true });
buttons.cancelButton.jqxButton({disabled: false});
buttons.updateButton.jqxButton({disabled: false});
break;
case ‘End Edit’:
break;
}renderToolbar = (toolBar) => {
let toTheme = (className) => {
if (this.theme == ”) return className;
return className + ‘ ‘ + className + ‘-‘ + this.theme;
// appends buttons to the status bar.
let container: any = $(‘<div class=”btn-toolbar” style=”background: #ffffff;”><div class=”btn-toolbar” style=”padding: 3px; overflow: hidden; position: relative; height: 100%; width: 100%;border:0px solid #cfd8dc”></div></div>’);
let buttonTemplate: any = ‘<div class=”btn-group mr-1″ style=”float: right;margin: 2px;”><div style=”margin: 4px;”></div></div>’;
let addPFButton: any = $(buttonTemplate)
let deletePFButton: any = $(buttonTemplate);
let addOpportunityButton: any = $(buttonTemplate)
let editButton: any = $(buttonTemplate);
let cancelButton: any = $(buttonTemplate);
let updateButton: any = $(buttonTemplate);
if(! ($(‘.btn-toolbar’).length > 0)){
container.append(addPFButton);
container.append(deletePFButton);
container.append(addOpportunityButton);
container.append(editButton);
container.append(updateButton);
container.append(cancelButton);
toolBar.append(container);
}addPFButton.jqxButton({cursor: ‘pointer’, disabled: true, enableDefault: false});
addPFButton.text(‘Add PF’).addClass(‘btn btn-primary’);deletePFButton.jqxButton({cursor: ‘pointer’, disabled: true, enableDefault: false});
deletePFButton.text(‘Delete PF’).addClass(‘btn btn-danger’);addOpportunityButton.jqxButton({cursor: ‘pointer’, disabled: true, enableDefault: false});
addOpportunityButton.text(‘Add Opportunity’).addClass(‘btn btn-primary’);editButton.jqxButton({cursor: ‘pointer’, disabled: true, enableDefault: false});
editButton.text(‘Edit’).addClass(‘btn btn-info’);updateButton.jqxButton({cursor: ‘pointer’, disabled: true, enableDefault: true});
updateButton.text(‘Save’).addClass(‘btn btn-success’);cancelButton.jqxButton({cursor: ‘pointer’, disabled: true, enableDefault: false});
cancelButton.text(‘Reset’).addClass(‘btn btn-danger’);this.buttonsObject = {
addPFButton: addPFButton,
deletePFButton:deletePFButton,
addOpportunityButton: addOpportunityButton,
editButton: editButton,
cancelButton: cancelButton,
updateButton: updateButton,
addPFButton.click((event) => {
if (!addPFButton.jqxButton(‘disabled’)) {
this.treeGrid.expandRow(this.rowKey);let currentRow = this.treeGrid.getRow(this.rowKey);
this.newProductFamily = this.formDealForecastingObject();
this.newProductFamily[‘aggregatedCustomer’] = currentRow[‘aggregatedCustomer’];
this.newProductFamily[‘salesRegion’] = currentRow[‘salesRegion’];
this.newProductFamily[‘subBusinessEntity’] = currentRow[‘subBusinessEntity’];
//this.newProductFamily[‘parentId’] = currentRow[‘id’];
// add new empty row.this.treeGrid.addRow(null, this.newProductFamily, ‘first’, this.rowKey);
// select the first row and clear the selection.
this.treeGrid.clearSelection();
//this.treeGrid.selectRow(this.newRowID);
this.updateButtons(‘add’, {}, this.buttonsObject);
addOpportunityButton.click((event) => {
if (!addOpportunityButton.jqxButton(‘disabled’)) {
let newOpportunity = this.formDealForecastingObject();
this.treeGrid.addRow(null, newOpportunity, ‘first’);
//this.treeGrid
// edit the new row.;
this.treeGrid.setColumnProperty(‘aggregatedCustomer’, ‘editable’, true);
this.treeGrid.setColumnProperty(‘salesRegion’, ‘editable’, true);
this.treeGrid.setColumnProperty(‘subBusinessEntity’, ‘editable’, true);
this.treeGrid.setColumnProperty(‘productFamily’, ‘editable’, true);
this.treeGrid.beginRowEdit(this.newRowID);
editButton.click(() => {
if (!editButton.jqxButton(‘disabled’)) {
this.treeGrid.unlockRow(this.rowKey);
this.treeGrid.beginRowEdit(this.rowKey);
this.updateButtons(‘edit’, {}, this.buttonsObject);
});deletePFButton.click(() => {
if (!deletePFButton.jqxButton(‘disabled’)) {
let selection = this.treeGrid.getSelection();
if (selection.length > 1) {
for (let i = 0; i < selection.length; i++) {
let key = this.treeGrid.getKey(selection[i]);
this.treeGrid.deleteRow(key);
else {
this.treeGrid.deleteRow(this.rowKey);
this.updateButtons(‘delete’,{}, this.buttonsObject);
});updateButton.click((event) => {
if (!updateButton.jqxButton(‘disabled’)) {
this.treeGrid.endRowEdit(this.rowKey, false);
});cancelButton.click((event) => {
if (!cancelButton.jqxButton(‘disabled’)) {
// cancel changes.
this.treeGrid.endRowEdit(this.rowKey, true);
rowKey = null;rowSelect(event: any): void {
let args = event.args;
this.rowKey = args.key;
this.currentRow = this.treeGrid.getRow(this.rowKey);
this.currentRow[‘rowKey’] = this.rowKey;
console.log(this.currentRow);
this.updateButtons(‘Select’, this.currentRow, this.buttonsObject);
let queryParams:any = {}
queryParams[‘subBusinessEntity’] = this.currentRow[‘subBusinessEntity’]
console.log(queryParams);
this.dashboardService.getProductFamilies(queryParams)
.subscribe(
result => {
this.productFamilyList = result.productFamilies;
rowUnselect(event: any): void {
//this.updateEditableFieldsStatus();
this.updateButtons(‘Unselect’, {}, this.buttonsObject);
};rowBeginEdit(event: any): void {
this.updateButtons(‘Edit’, {}, this.buttonsObject);
};rowEndEdit(event: any): void {
this.updateButtons(‘End Edit’, {}, this.buttonsObject);
};myTreeGridOnPageChanged(event: any): void {
console.log(“Page:” + args.pagenum + “, Page Size: ” + args.pageSize);
};myTreeGridOnPageSizeChanged(event): void {
console.log(“Page:” + args.pagenum + “, Page Size: ” + args.pageSize + “, Old Page Size: ” + args.oldpageSize);
};formDealForecastingObject(): any {
var dealForecasting = {
pfId: null,
productFamily: null,
pmBottomsUp: null,
pmRisk: null,
pmUpside: null,
pmProbability: null,
pmEstimatedQ1FyForecast: null,
pmEstimatedQ2FyForecast: null,
pmEstimatedQ3FyForecast: null,
pmEstimatedQ4FyForecast: null,
pmComments: null,
pmTimeStamp: null,
baCurrentSalesForecast: null,
baBottomsUp: null,
baRisk: null,
baUpside: null,
baProbability: null,
criticalDeal: null,
baStatus: null,
baComments: null,
baExecutiveSummary: null,
fiscalQuarterId: null,
salesRegion: null,
aggregatedCustomer: null,
subBusinessEntity: null,
finBookingsActuals: null,
sfdcCommit: null,
sfdcWeekByWeekActuals: null,
sfdcActualsPlusCommit: null,
sfdcUpside: null,
fy11: null,
fy12: null,
fy13: null,
fy14: null,
fy21: null,
fy22: null,
fy23: null,
fy24: null,
return dealForecasting;
Hi Team,
Any inputs on this, please?
Thanks & regards
Sandeep VedavyasThe Tree Grid does not support server side pagination. It supports loading data on demand when a record is expanded which is a different approach.
https://www.jqwidgets.com/Is there any other way to get batch wise records? if I can update the treeGird total records, I think it will enable page buttons ?
The Tree grid does not know what is total records and things like that known in flat tables. As a hierarchical data component, It supports loading on demand by expanding a record.
https://www.jqwidgets.com/ -
