jQuery UI Widgets Forums Grid ServerPaging with Oracle and JSP
This topic contains 4 replies, has 2 voices, and was last updated by  Dimitar 8 years, 4 months ago.
  • ServerPaging with Oracle and JSP #89653
    ligun89
    Howdy guys!
    I have a tiny question and wish you guys help me out :'(
    I have a Oracle DB and its size is kinda huge tho. So I would use ServerPaging with Oracle and JSP
    I was gonna use a example like this (http://www.jqwidgets.com/jquery-widgets-documentation/documentation/java-integration/grid-server-side-sorting-paging-filtering-using-jsp.htm). However, I got to have some errors.. my sources are as below.
        <title id='Description'>This example demonstrates how to implement server sorting, paging and filtering with jqxGrid, JSP and MySQL.</title>
        <link rel="stylesheet" href="jqwidgets/styles/jqx.base.css" type="text/css" />
        <script type="text/javascript" src="scripts/jquery-1.11.1.min.js"></script>
        <script type="text/javascript" src="jqwidgets/jqxbuttons.js"></script>
        <script type="text/javascript" src="jqwidgets/jqxscrollbar.js"></script>
        <script type="text/javascript" src="jqwidgets/jqxlistbox.js"></script>
        <script type="text/javascript" src="jqwidgets/jqxmenu.js"></script>
        <script type="text/javascript" src="jqwidgets/jqxgrid.js"></script>
        <script type="text/javascript" src="jqwidgets/jqxgrid.selection.js"></script>
        <script type="text/javascript" src="jqwidgets/jqxgrid.filter.js"></script>
        <script type="text/javascript" src="jqwidgets/jqxgrid.sort.js"></script>
        <script type="text/javascript" src="jqwidgets/jqxdata.js"></script>
        <script type="text/javascript" src="jqwidgets/jqxgrid.pager.js"></script>
        <script type="text/javascript" src="jqwidgets/jqxdropdownlist.js"></script>
        <script type="text/javascript" src="scripts/demos.js"></script>
                var source = {
                    datafields: [{
                        type: 'string'
                        type: 'string'
                        type: 'string'
                    cache: false,
                    url: 'jsp/select-filtered-data.jsp',
                    filter: function() {
                    sort: function() {
                    beforeprocessing: function(data) {
                        if (data != null && data.length > 0) {
                            source.totalrecords = data[0].totalRecords;
                var filterChanged = false;
                    // remove the comment to debug
                    formatData: function(data) {
                        alert(JSON.stringify(data));
                        return data;
                    downloadComplete: function(data, status, xhr) {
                        if (!source.totalRecords) {
                            source.totalRecords = data.length;
                    loadError: function(xhr, status, error) {
                        throw new Error(error);
                // initialize jqxGrid
                $("#jqxgrid").jqxGrid({
                    width: 550,
                    source: dataadapter,
                    pagesize: 3,
                    pagesizeoptions: ['3', '4', '5'],
                    virtualmode: true,
                    rendergridrows: function(obj) {
                        return obj.data;
                    columns: [{
                        text: 'NAME',
                        datafield: 'NAME',
                        width: 100
                        text: 'CONTENT',
                        datafield: 'CONTENT',
                        width: 100
                        text: 'SYS_DATE',
                        datafield: 'SYS_DATE',
                        width: 180
        <div id="jqxgrid">
    <%@ page import="java.lang.*,java.sql.*,com.google.gson.*,org.json.simple.*,java.util.*"%>
        String where = "";
        Integer filterscount = 0;
        if (null != request.getParameter("filterscount"))
            try
                filterscount = Integer.parseInt(request.getParameter("filterscount"));
            catch (NumberFormatException nfe) {}
        if (filterscount > 0) {
            where = " WHERE (";
            String tmpdatafield = "";
            String tmpfilteroperator = "";
            for (Integer i=0; i < filterscount; i++)
                String filtervalue = request.getParameter("filtervalue" + i);
                String filtercondition = request.getParameter("filtercondition" + i);
                String filterdatafield = request.getParameter("filterdatafield" + i);
                filterdatafield = filterdatafield.replaceAll("([^A-Za-z0-9])", "");
                String filteroperator = request.getParameter("filteroperator" + i);
                if (tmpdatafield.equals(""))
                    tmpdatafield = filterdatafield;
                else if (!tmpdatafield.equals(filterdatafield))
                    where += ")AND(";
                else if (tmpdatafield.equals(filterdatafield))
                    if (tmpfilteroperator.equals("0"))
                        where += " AND ";
                    else where += " OR ";
                // build the "WHERE" clause depending on the filter's condition, value and datafield.
                switch(filtercondition)
                    case "CONTAINS":
                        where += " " + filterdatafield + " LIKE '%" + filtervalue + "%'";
                        break;
                    case "CONTAINS_CASE_SENSITIVE":
                        where += " " + filterdatafield + " LIKE BINARY '%" + filtervalue + "%'";
                        break;
                    case "DOES_NOT_CONTAIN":
                        where += " " + filterdatafield + " NOT LIKE '%" + filtervalue + "%'";
                        break;
                    case "DOES_NOT_CONTAIN_CASE_SENSITIVE":
                        where += " " + filterdatafield + " NOT LIKE BINARY '%" + filtervalue + "%'";
                        break;
                    case "EQUAL":
                        where += " " + filterdatafield + " = '" + filtervalue + "'";
                        break;
                    case "EQUAL_CASE_SENSITIVE":
                        where += " " + filterdatafield + " LIKE BINARY '" + filtervalue + "'";
                        break;
                    case "NOT_EQUAL":
                        where += " " + filterdatafield + " NOT LIKE '" + filtervalue + "'";
                        break;
                    case "NOT_EQUAL_CASE_SENSITIVE":
                        where += " " + filterdatafield + " NOT LIKE BINARY '" + filtervalue + "'";
                        break;
                    case "GREATER_THAN":
                        where += " " + filterdatafield + " > '" + filtervalue + "'";
                        break;
                    case "LESS_THAN":
                        where += " " + filterdatafield + " < '" + filtervalue + "'";
                        break;
                    case "GREATER_THAN_OR_EQUAL":
                        where += " " + filterdatafield + " >= '" + filtervalue + "'";
                        break;
                    case "LESS_THAN_OR_EQUAL":
                        where += " " + filterdatafield + " <= '" + filtervalue + "'";
                        break;
                    case "STARTS_WITH":
                        where += " " + filterdatafield + " LIKE '" + filtervalue + "%'";
                        break;
                    case "STARTS_WITH_CASE_SENSITIVE":
                        where += " " + filterdatafield + " LIKE BINARY '" + filtervalue + "%'";
                        break;
                    case "ENDS_WITH":
                        where += " " + filterdatafield + " LIKE '%" + filtervalue + "'";
                        break;
                    case "ENDS_WITH_CASE_SENSITIVE":
                        where += " " + filterdatafield + " LIKE BINARY '%" + filtervalue + "'";
                        break;
                    case "NULL":
                        where += " " + filterdatafield + " IS NULL";
                        break;
                    case "NOT_NULL":
                        where += " " + filterdatafield + " IS NOT NULL";
                        break;
                if (i == filterscount - 1)
                    where += ")";
                tmpfilteroperator = filteroperator;
        String orderby = "";
        String sortdatafield = request.getParameter("sortdatafield");
        String sortorder = request.getParameter("sortorder");
        if (sortdatafield != null && sortorder != null && (sortorder.equals("asc") || sortorder.equals("desc")))
            sortdatafield = sortdatafield.replaceAll("([^A-Za-z0-9])", "");
            orderby = "order by " + sortdatafield + " " + sortorder;
        Integer pagenum = 0;
        if (null != request.getParameter("pagenum"))
            try
                pagenum = Integer.parseInt(request.getParameter("pagenum"));
        Integer pagesize = 1000;
        if (null != request.getParameter("pagesize"))
            try
                pagesize = Integer.parseInt(request.getParameter("pagesize"));
        Integer start = pagesize * pagenum;
        // database connection
        // "jdbc:mysql://localhost:3306/northwind" - the database url of the form jdbc:subprotocol:subname
        Connection dbConnection = DriverManager.getConnection("jdbc:oracle:thin:@192.168.xxx.xxx:TEST", "dbusername", "dbpassword");
        // retrieve necessary records from database
        Statement getFromDb = dbConnection.createStatement();
        ResultSet totalEmployees = getFromDb.executeQuery("SELECT COUNT(*) AS Count FROM PEG.TEST_BOARD" + where);
        String totalRecords = "";
        while (totalEmployees.next()) {
            totalRecords = totalEmployees.getString("Count");
        totalEmployees.close();
        String sql = "SELECT NAME,CONTENT,SYS_DATE FROM PEG.TEST_BOARD " + where + " " + orderby + " LIMIT ?,?";
        PreparedStatement stmt = dbConnection.prepareStatement(sql);
        stmt.setInt(1, start);
        stmt.setInt(2, pagesize);
        ResultSet employees = stmt.executeQuery();
        boolean totalRecordsAdded = false;
        // format returned ResultSet as a JSON array
        JsonArray recordsArray = new JsonArray();
        while (employees != null && employees.next()) {
            JsonObject currentRecord = new JsonObject();
            currentRecord.add("NAME", new JsonPrimitive(employees.getString("NAME")));
            currentRecord.add("CONTENT", new JsonPrimitive(employees.getString("CONTENT")));
            currentRecord.add("SYS_DATE", new JsonPrimitive(employees.getString("SYS_DATE")));
            if (totalRecordsAdded == false) {
                // add the number of filtered records to the first record for client-side use
                currentRecord.add("totalRecords", new JsonPrimitive(totalRecords));
                totalRecordsAdded = true;
            recordsArray.add(currentRecord);
        out.print(recordsArray);
        out.flush();
    ServerPaging with Oracle and JSP #89666
    Hello ligun89,
    Could you, please, share what errors are thrown in your browser’s console? Please also note that we can only assist you with your client-side code regarding the use of jQWidgets and that we generally do not review server-side code.
    ServerPaging with Oracle and JSP #89669
    ligun89
    This is an error I got from Chrome console.
    Failed to load resource: the server responded with a status of 404 (Not Found)
    Uncaught Error: Not Found
    at Object.loadError (http://192.168.211.28:8080/serverPaging.html:64:27)
    at Object.error (http://192.168.211.28:8080/jqwidgets/jqxdata.js:7:22547)
    at j (http://192.168.211.28:8080/scripts/jquery-1.11.1.min.js:2:27244)
    at Object.fireWith [as rejectWith] (http://192.168.211.28:8080/scripts/jquery-1.11.1.min.js:2:28057)
    at S (http://192.168.211.28:8080/jqwidgets/jqxdata.js:7:64496)
    at XMLHttpRequest.H (http://192.168.211.28:8080/jqwidgets/jqxdata.js:7:70895)
    I understand this part of source is not your stuff..but i’m striving to solve this problem in order to use JQWidget.
    So, if you have any idea, please let me know that. Thank you.
    ServerPaging with Oracle and JSP #89675
    ligun89
    Sorry, ignore above error message. I mistook my server address.
    This is an error… please look at this.
    Navigated to http://192.168.211.28:8080/serverPaging.html
    GET http://192.168.211.28:8080/jsp/select-filtered-data.jsp?filterscount=0&grou…0&pagenum=0&pagesize=3&recordstartindex=0&recordendindex=3&_=1481186720117 404 (Not Found)
    XHR finished loading: GET “http://192.168.211.28:8080/jsp/select-filtered-data.jsp?filterscount=0&grou…0&pagenum=0&pagesize=3&recordstartindex=0&recordendindex=3&_=1481186720117”.
    ServerPaging with Oracle and JSP #89695
    Hello ligun89,
    Are you sure there is a file select-filtered-data.jsp in your project? This is the name of the demo JSP file from our tutorial. Please set the source object’s url to the path to an existing file that processes data from your database.
