jQuery UI Widgets Forums Grid server side problem (filterrow)
This topic contains 2 replies, has 2 voices, and was last updated by  leefuchu 9 years, 10 months ago.
  • server side problem (filterrow) #72695
    leefuchu
    Hi jqWidgets Team
    I found a strange phenomenon when i implements filter row function(server side).
    when i inputs text for searching, the filter funciton is fired once.
    but i use input text with dropdownlist for searching, the filter function is fired twice.
    Example>
    https://tagme.to/fuchu/jqxgridfilterproblem
    code ——————————————————
    data : params,
    url: “i/sample/sampleGcsGetCust.ajax” ,
    // root: ‘grid’,
    async: false,
    datafields:
    { name: ‘customerid’, type: ‘string’ },
    { name: ‘customernm’, type: ‘string’ },
    { name: ‘enterdt’, type: ‘string’ }
    // and with parameter false if the synchronization failder.
    commit(true);
    sort: function (data) {
    filter: function (data) {
    processdata: function (data) {
    formatdata: function(data){
    return null;
    source.totalrecords = data.count;
    source.records = data.grid;
    beforeSend: function(data){
    pagechange: function(data)
    loadComplete: function(data){
    // initialize jqxGrid
    $(“#jqxgrid”).jqxGrid({
    source: dataAdapter
    server side problem (filterrow) #72714
    Hi leefuchu,
    The filter function is called whenever filter is added or removed. If it’s called, then the Grid assummes that it is necessary the function to be called.
    server side problem (filterrow) #72725
    leefuchu
    hi peter.
    yes, you are right. when the filter is added, filter function is fired once.
    but when i add filter by dropdownlist, filter function is fired twice. that is problem.
    (See the attached video)
    so The below of the method can not be used.
    http://www.jqwidgets.com/jquery-widgets-documentation/documentation/jqxgrid/jquery-grid-php-server-side-processing.htm
