jQuery UI Widgets › Forums › Grid › Server-side paging problems when sorting enabled
This topic contains 4 replies, has 3 voices, and was last updated by elmemo14 12 years, 8 months ago.
I have a problem of virtual paging when sorting enabled, when I go to the next page, I got the error: Uncaught TypeError: Cannot read property ‘value’ of undefined, below is the code:
<!DOCTYPE html> <html lang="en"> <head> <meta charset="utf-8" /> <title>jqxGrid Demo</title> <meta name="viewport" content="width=device-width, initial-scale=1.0, user-scalable=0, minimum-scale=1.0, maximum-scale=1.0"> <script src="base/jquery-1.7.1.min.js"></script> <link rel="stylesheet" href="styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="scripts/jqxcore.js"></script> <script type="text/javascript" src="scripts/jqxdata.js"></script> <script type="text/javascript" src="scripts/jqxbuttons.js"></script> <script type="text/javascript" src="scripts/jqxscrollbar.js"></script> <script type="text/javascript" src="scripts/jqxlistbox.js"></script> <script type="text/javascript" src="scripts/jqxdropdownlist.js"></script> <script type="text/javascript" src="scripts/jqxgrid.js"></script> <script type="text/javascript" src="scripts/jqxgrid.sort.js"></script> <script type="text/javascript" src="scripts/jqxgrid.pager.js"></script> <script type="text/javascript" src="scripts/jqxgrid.grouping.js"></script> <script type="text/javascript" src="scripts/jqxgrid.selection.js"></script> <script type="text/javascript"> $(document).ready(function () { var source = { datatype: 'jsonp', datafields: [{ name: 'Beskrivelse' }, { name: 'Nummer' }, { name: 'Start' }, { name: 'Slutt' }, { name: 'Status' } ], url: 'http://vaf.vegasmb.com:8101/ServiceDebug/Service.svc/Test?method=?', root: 'Rows', beforeprocessing: function (data) { var json = $.parseJSON(data.TestResult); source.totalrecords = json.TotalRows; } }; var dataAdapter = new $.jqx.dataAdapter(source, { downloadComplete: function (data) { return $.parseJSON(data['TestResult']); } }); $("#jqxgrid").jqxGrid( { width: 670, source: dataAdapter, columnsresize: true, pageable: true, sortable: true, virtualmode: true, rendergridrows: function () { return dataAdapter.records; }, columns: [{ text: 'Description', dataField: 'Beskrivelse', minwidth: 100, classname: 'header', cellclassname: 'textcell' }, { text: 'Number', dataField: 'Nummer', minwidth: 100, classname: 'header', cellclassname: 'textcell' }, { text: 'Start', dataField: 'Start', minwidth: 100, classname: 'header', cellclassname: 'textcell' }, { text: 'End', dataField: 'Slutt', minwidth: 100, classname: 'header', cellclassname: 'textcell' }, { text: 'Status', dataField: 'Status', minwidth: 100, classname: 'header', cellclassname: 'textcell' } ], ready: function () { $("#jqxgrid").jqxGrid('sortby', 'Beskrivelse', 'asc'); } }); }); </script> <style type="text/css"> .header { font-weight: bold; font-size: 14px; /*margin-top:5px;*/ } .textcell { /*color:Black;*/ } .numbercell { color: Red; } </style> </head> <body class='default'> <div id='jqxWidget' style="font-size: 13px; font-family: Verdana; float: left;"> <div id="jqxgrid"> </div> </div> </body> </html>
Please help me to investigate this problem…
Thanks and best regards,
vudhHi vudh,
Please take a look at this help topic which shows how to implement Server Side Paging and Sorting: php-server-side-grid-paging-and-sorting.htm. If the help topic does not help, please send a sample project which demonstrates the issue to support@jqwidgets.com.
Peter StoevjQwidgets Team
Thanks for your help ! it works now.
By the way, the grid doesn’t show the loading image when paging takes a long time to response. How can I show it?
Thanks once again,
vudhThanks for the feedback! We’ll test the reported behavior.
http://www.jqwidgets.comvudh i am having the same sorting problem you had so if it possible please tell me how you solved the problem
