jQuery UI Widgets Forums Grid Server Paging Problem
This topic contains 3 replies, has 2 voices, and was last updated by  Dimitar 10 years, 3 months ago.
  • Server Paging Problem #66069
    EPSakhno
    There is a problem with the display of the last page of the table using the paging server
    Outputting the data is not correct
    example:
    $(“#grid”).jqxGrid(
    width: ‘100%’,
    showaggregates: true,
    showstatusbar: true,
    theme: ‘metro’,
    showfilterrow: true,
    virtualmode: true,
    return obj.data;
    pagesizeoptions: [‘5′, ’20’, ’50’, ‘100’],
    pagesize: 5,
    /*initialization columns*/
    $.post(‘/Home/GetTransaction’, {
    dateEnd: new Date($(“#dateStart_Raw”).jqxDateTimeInput(‘getDate’)).toISOString(),
    dateStart: new Date($(“#dateStart_Raw”).jqxDateTimeInput(‘getDate’)).toISOString(),
    ServicesList: $(‘select[name=ServicesList]’).val(),
    SupplierList: $(‘select[name=SupplierList]’).val()
    }, function (data) {
    { name: ‘Account’, type: ‘string’ },
    { name: ‘Amount’, type: ‘float’ },
    { name: ‘Card_amount’, type: ‘float’ },
    { name: ‘Cash_amount’, type: ‘float’ },
    { name: ‘Ecard_amount’, type: ‘float’ },
    { name: ‘BankAccount’, type: ‘float’ },
    { name: ‘BankMfo’, type: ‘float’ },
    { name: ‘BankName’, type: ‘string’ },
    { name: ‘BankName2’, type: ‘string’ },
    { name: ‘CommissionClient’, type: ‘float’ },
    { name: ‘CommissionProvider’, type: ‘float’ },
    { name: ‘Currency’, type: ‘string’ },
    { name: ‘DatePayment’, type: ‘date’ },
    { name: ‘PaymentDetails’, type: ‘string’ },
    { name: ‘ServiceId’, type: ‘int’ },
    { name: ‘ServiceName’, type: ‘string’ },
    { name: ‘StatusId’, type: ‘float’ },
    { name: ‘SuplierId’, type: ‘int’ },
    { name: ‘SupplierEdrpou’, type: ‘string’ },
    { name: ‘SupplierName’, type: ‘string’ },
    { name: ‘TerminalId’, type: ‘int’ },
    { name: ‘TransactionId’, type: ‘long’ }
    localdata: data.Rows,
    totalrecords: data.TotalRows
    // initialize jqxGrid
    $(“#grid”).jqxGrid(
    source: dataAdapter
    Here everything is working properly
    Paging works like this:
    $(“#grid”).on(“pagechanged”, function (event) {
    var args = event.args;
    var pageNum = args.pagenum;
    var pageSize = args.pagesize;
    $(“#grid”).jqxGrid(‘showloadelement’);
    $.post(‘/Home/GetTransactionPage’, {
    pagesize: pageSize, pagenum: pageNum,
    dateEnd: new Date($(“#dateEnd_Raw”).jqxDateTimeInput(‘getDate’)).toISOString(),
    type: “GET”,
    root: ‘Rows’,
    localdata: data,
    totalrecords:data.TotalRows
    $(“#grid”).jqxGrid({ source: dataAdapter });
    Everything works, but on the last page, the data is not displayed
    When I put a breakpoint, and turn on the penultimate page.
    before receiving the data, see the data from the last page displayed on the second page.
    Thank You for help
    Server Paging Problem #66121
    Hello EPSakhno,
    Please refer to the available server-side paging help topics: Server Side Paging with jqxGrid using PHP and MySQL, Server-Side Paging with jqxGrid, ASP.NET MVC 3 and SQL or Server Paging with jqxGrid, ASP.NET and SQL. We hope one of these helps you implement this functionality as you require.
    Server Paging Problem #66128
    EPSakhno
    Another question.
    I need to ask for resources to pass parameters to the method.
    example:
      var source = {
                 datafields: [{name: ‘ShippedDate’, type: ‘date’},
    {Name: ‘ShipName’},
    {Name: ‘ShipAddress’},
    {Name: ‘ShipCity’},
    {Name: ‘ShipCountry’}],
                 url: ‘Orders / GetOrders’,
                 root: ‘Rows’,
                     source.totalrecords = data.TotalRows;
    But GetOrders method, I want to pass a value:
    new Date ($ (“# dateEnd_Raw”). jqxDateTimeInput (‘getDate’)). toISOString ()
    As indicated in the resource?
    Server Paging Problem #66161
    Hi EPSakhno,
    You can use the source data property to pass data to the server. For more information, please refer to the jqxDataAdapter help topic. You may also find the tutorial Add extra HTTP variables helpful.
