jQuery UI Widgets Forums Grid Send filter in body
This topic contains 3 replies, has 2 voices, and was last updated by  Martin 6 years, 6 months ago.
  • Send filter in body #102326
    Eli1
    Hello!
    I am using jqxGrid one page filtering.
    I have a lot of filters items in column,
    when I send the parameters its send in the url
    because its too much parameters i am getting an error message.
    There is a way to send the filters value in body to get over it?
    Send filter in body #102330
    Martin
    Hello Eli1,
    You can get the filter information at any time using the getfilterinformation method.
    You can check this Demo.
    Martin
    Send filter in body #102342
    Eli1
    hey again,
    i’m using:
    filter: function() {
    to filter and i’m sending to sever above 7000 characters
    and its append it to the url, how i can send the filters with json? i’m using asp mvc
    Send filter in body #102369
    Martin
    Hello Eli1,
    I would suggest you to read this Documentation about adding extra HTTP variables.
    If this would not help, can you send us an example where this issue can be reproduced?
    Martin
