jQuery UI Widgets Forums Grid selectrow and row values
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 11 years ago.
  • selectrow and row values #53147
    dbmw
    If I am able to select a row by doing this, assuming that I have row as a variable with value 2 for example
    $("#grid").jqxGrid('selectrow', row);
    Why will this command, where recid is a column in my grid, run immediately after give me a null result?
    var idINeed = $('#grid').jqxGrid('getcellvalue', row, "recid");
    thanks
    Mark
    selectrow and row values #53153
    Hello Mark,
    This is not a normal behaviour. Please post a larger code sample, which we may test locally to determine the source of the issue. A JSFiddle would be fine, too. Make sure you are using the latest version of jQWidgets (3.2.2).
