jQuery UI Widgets Forums Grid right click on empty grid
This topic contains 3 replies, has 4 voices, and was last updated by  Dimitar 9 years, 3 months ago.
  • right click on empty grid #76378
    omargarro
    I want to open my context-menu on right-click over my grid.
    .on(‘rowclick’, function (event) {
    if (event.args.rightclick) {
    contextMenu.jqxMenu(‘open’, parseInt(event.args.originalEvent.clientX) + 5 + scrollLeft, parseInt(event.args.originalEvent.clientY) + 5 + scrollTop);
    return false;
    everything works fine except when I have an empty grid (No data to display). And I think that’s what it´s expected.
    How can I force that anyway ?
    right click on empty grid #76426
    Vladimir
    Hello omargarro,
    There is no exposed method from the widget to trigger on empty rows, however you can bind to a regular click event on the grid and check if it is clicked on an empty row.
    Here is an example:
    $('#jqxgrid').on('click', function (event) {
        if ($(event.target).hasClass('jqx-grid-cleared-cell')){
        	// enter code to handle empty row click
    Or if you want the same code to handle clicks on all rows (empty or not) you can check for the jqx-grid-cell class:
        if ($(event.target).hasClass('jqx-grid-cell')){
        	// enter code to handle any row click
    The check for target is needed, as otherwise the code would trigger when you click on scrollers and headers as well, so it is up to you to decide where you want to trigger it.
    Vladimir
    right click on empty grid #80006
    Siva
    Empty Grid right click event not get triggered for the contest menu. hasClass() method is not get triggered in empty grid.
    right click on empty grid #80014
    Hello Siva,
    Please refer to the following example:
        <script type="text/javascript" src="../../jqwidgets/jqxgrid.aggregates.js"></script>
                $("#jqxgrid").on('contextmenu', function () {
                    return false;
                var data = generatedata(0);
                var source = {
                    localdata: data,
                    datafields: [{
                        type: 'string'
                        type: 'string'
                        type: 'string'
                        type: 'date'
                        type: 'number'
                        type: 'number'
                    datatype: "array"
                $("#jqxgrid").jqxGrid({
                    width: 500,
                    theme: 'energyblue',
                    height: 300,
                    source: adapter,
                    ready: function () {
                        $('#jqxgrid').on('mousedown', function (event) {
                            if (event.which === 3 && $(event.target).hasClass('jqx-grid-empty-cell')) {
                                alert('Right-clicked empty grid.');
                    columns: [{
                        text: 'First Name',
                        datafield: 'firstname',
                        width: 90
                        text: 'Last Name',
                        datafield: 'lastname',
                        width: 90
                        text: 'Product',
                        datafield: 'productname',
                        width: 170
                        text: 'Order Date',
                        datafield: 'date',
                        width: 160,
                        cellsformat: 'dd-MMMM-yyyy'
                        text: 'Quantity',
                        datafield: 'quantity',
                        width: 80,
                        cellsalign: 'right'
                        text: 'Unit Price',
                        datafield: 'price',
                        cellsalign: 'right',
                        cellsformat: 'c2'
        <div id="jqxgrid">
    We hope it is helpful to you.
