jQuery UI Widgets Forums Grid Retrieve values in jqxGrid with jqxComboBox – Checkbox
This topic contains 8 replies, has 3 voices, and was last updated by  Dimitar 9 years, 9 months ago.
  • paulo.junior
    We are trying to use the combo box with multi values ​​in my grill .
    In our case, we have a list with the check box .
    What we were unable to initialize the grid with each record line the values ​​recorded in the combobox .
    Please wait for your help.
    grateful
    Part of our source code:
    //Source Adpater do Representante
    var representanteSource =
    { name: ‘RepresentanteId’ },
    { name: ‘Nome’ }
    //{ name: ‘Selecionado’ }
    url: “/P100D/Representante/Lista”,
    async: false
    var representanteAdapter = new $.jqx.dataAdapter(representanteSource, {
    autoBind: true,
    var data = new Array();
    for (var i = 0; i < records.length; i++) {
    var representante = records[i];
    representante.RepresentanteId = representante.RepresentanteId;
    //representante.checked = representante.checked;
    representante.Nome = representante.Nome;
    data.push(representante);
    return data;
    //EndPoint
    var url = “/P100D/Solicitacao/Lista”;
    type: “GET”,
    datafields:
    { name: ‘SolicitacaoId’, type: ‘string’ },
    { name: ‘RepresentanteDesc’, map: ‘Representantes>Nome’, value: ‘RepresentanteId’, values: { source: representanteAdapter.records, value: ‘RepresentanteId’, name: ‘Nome’ } },
    { name: ‘RepresentanteIds’ },
    url: url,
    addrow: function (rowid, rowdata, commit, position) {
    updaterow: function (rowid, rowdata, commit) { },
    deleterow: function (rowid, rowdata, commit, dtrowid) {}
    // initialize jqxGrid
    $(“.P100D-Solicitacao”).jqxGrid(
    width: ‘100%’,
    height: ‘100%’,
    ready: function () {
    $(“.P100D-Solicitacao”).jqxGrid(‘hidecolumn’, ‘SolicitacaoId’);
    $(“.P100D-Solicitacao”).jqxGrid(‘localizestrings’, toolBarJQWidgets());
    showeverpresentrow: true,
    everpresentrowposition: “top”,
    //everpresentrowactionsmode: “columns”,
    everpresentrowactions: “add remove reset”,//update
    pagesizeoptions: [’30’, ’60’, ’90’, ‘120’, ‘150’, ‘180’, ‘210’],
    pagesize: 30,
    autoheight: false,
    altrows: true,
    theme: ‘office’,
    columnsresize: false,
    enabletooltips: true,
    filtermode: ‘excel’,
    enablehover: true,
    groupable: false,
    showgroupsheader: false,
    //selectionmode: ‘multiplecellsadvanced’,
    localization: {
    culture: getLocalization(‘pt-BR’),
    everpresentrowplaceholder: “Digite: “,
    addrowstring: “Novo”,
    udpaterowstring: “Atualizar”,
    deleterowstring: “Excluir”,
    resetrowstring: “Limpar”,
    //Representantes
    text: ‘Representantes’, cellclassname: cellclass, // (Áreas Impactadas) – (min. 1; máx. 5)
    columntype: ‘dropdownlist’,
    datafield: ‘RepresentanteId’,
    displayfield: ‘RepresentanteDesc’,
    width: 230,
    createEverPresentRowWidget: function (datafield, htmlElement) {
    var inputTag = $(“<div style=’border: none;’></div>”).appendTo(htmlElement);
    inputTag.jqxDropDownList({
    checkboxes: true,
    popupZIndex: 99999999,
    placeHolder: “Informe os Representantes: “,
    source: representanteAdapter,
    displayMember: ‘Nome’,
    valueMember: ‘RepresentanteId’,
    width: ‘100%’,
    height: 30,
    theme: ‘office’
    return inputTag;
    initEverPresentRowWidget: function(datafield, htmlElement) {
    getEverPresentRowWidgetValue: function (datafield, htmlElement, validate) {
    var value = htmlElement.val(); return value;
    resetEverPresentRowWidgetValue: function (datafield, htmlElement) {
    htmlElement.val(null);
    // construct the editor.
    editor.jqxDropDownList({
    checkboxes: true,
    //selectedIndex: 1,
    height: 30,
    theme: ‘office’,
    selectionRenderer: function () {
    return “<span style=’top:4px; position: relative;’>Informe os Representantes:</span>”;
    initeditor: function (row, value, editor) {
    //set the editor’s current value. The callback is called each time the editor is displayed.
    var items = editor.jqxDropDownList(‘getItems’);
    editor.jqxDropDownList(‘uncheckAll’);
    var values = cellvalue.split(/,\s*/);
    for (var j = 0; j < values.length; j++) {
    for (var i = 0; i < items.length; i++) {
    if (items[i].label === values[j]) {
    editor.jqxDropDownList(‘checkIndex’, i);
    geteditorvalue: function (row, value, editor) {
    // return the editor’s value.
    return editor.val();
    jgarcias
    It is exactly what I have been asking for in my last post:
    http://www.jqwidgets.com/community/topic/initialize-combobox-column-in-jqxgrid/
    paulo.junior
    Hello JGarcias,
    I saw the Post but into’m still not a solution how to handle this case, to recover the data in the independent lines is the same question that the Ivalo answered him today below. He is unable to recover the data on independent lines.
    The combobox with checkbox, works perfectly selection, however I am unable to retrieve selected data.
    hugs,
    Hello paulo.junior,
    So, basically, you have a grid with its own data source, but one of its columns (“Representantes”) has to be populated from another data source, which also populates the column’s combobox editor. If this is the case, the correct approach is to implement a Foreign Key Column – something you have tried, but I am not sure why your code does not work. We would need some sample data from both sources to be able to test your example and determine the why the issue occurs. Any more clarification on the issue is welcome, too.
    paulo.junior
    Hello Dimitar,
      Thanks for the quick reply, I will try to summarize what we are doing in the meantime will see a way to try to expose the code so that you can analyze and tell us whether we are doing right or wrong.
      I got your foreign key approach to fill another column with a different adapter. But what we are doing is a Source that contains the information of the pillars of our Grid and Adapter to the to the column of Representatives in the case.
      Our greatest difficulty is when we use the combobox component of multiple selection with checkbox, because in the beginning of the line mark the desired representatives to the log line and these representatives who are selected are not checked in the line was inserted in the bank , the bank contains it’s ID, but we are unable to make the jqxCombobox populate the data that was selected in the first record.
      This being our problem, the issue of foreign key think it would be not the case, because I want to recover data that has been checked in the registry first, to have an update on the same grid.
    Hugs,
    And is that I managed to explain what we want?
    Paulo Junior
    paulo.junior
    I’m putting down our entire code, setting the grid and adapters that are using to populate the combo box in the grid. We had to make a change in the multiple selection, so I put the checkboxes attribute = false. For while we can not recover the data put them without multiple selection.
    `$(document).ready(function () {
    plano100DSolicitacao();
    /* END POINTS DO SISTEMA */
    //Solicitação: http://localhost:21472/P100D/Solicitacao/Lista
    //Fase: http://localhost:21472/P100D/Fase/Lista
    //Classe: http://localhost:21472/P100D/Classe/Lista
    //Sponsor: http://localhost:21472/P100D/Sponsor/ListarTodosElegiveis
    //Responsável: http://localhost:21472/P100D/Responsavel/Lista
    //Recurso: http://localhost:21472/P100D/Recurso/Lista
    //Representante: http://localhost:21472/P100D/Representante/Lista
    function plano100DSolicitacao() {
    //Source Adpater dos Responsável
    var responsavelSource =
    { name: ‘ResponsavelId’ },
    { name: ‘Nome’ }
    url: “/P100D/Responsavel/Lista”,
    async: false
    var responsavelAdapter = new $.jqx.dataAdapter(responsavelSource, {
    autoBind: true,
    var responsavel = records[i];
    responsavel.ResponsavelId = responsavel.ResponsavelId;
    responsavel.Nome = responsavel.Nome;
    data.push(responsavel);
    return data;
    //Source Adpater do Sponsor
    var sponsorSource =
    { name: ‘SponsorId’ },
    { name: ‘Nome’ }
    url: “/P100D/Sponsor/ListarTodosElegiveis”,
    async: false
    var sponsorAdapter = new $.jqx.dataAdapter(sponsorSource, {
    autoBind: true,
    var sponsor = records[i];
    sponsor.SponsorId = sponsor.SponsorId;
    sponsor.Nome = sponsor.Nome;
    data.push(sponsor);
    return data;
    //Source Adpater do Recursos
    var recursoSource =
    { name: ‘UsuarioId’ },
    { name: ‘Nome’ }
    //{name: ‘Selecionado’}
    url: “/P100D/Recurso/Lista”,///P100D/Recurso/Lista
    async: false
    var recursoAdapter = new $.jqx.dataAdapter(recursoSource, {
    autoBind: true,
    var recurso = records[i];
    recurso.UsuarioId = recurso.UsuarioId;
    //recurso.checked = recurso.Selecionado;
    recurso.Nome = recurso.Nome;
    data.push(recurso);
    return data;
    { name: ‘Nome’ }
    async: false
    autoBind: true,
    return data;
    //Source Adpater do Classe
    var classeSource =
    { name: ‘ClasseId’ },
    { name: ‘Descricao’ }
    url: “/Cadastro/P100DClasse/Lista”,
    async: false
    var classeAdapter = new $.jqx.dataAdapter(classeSource, {
    autoBind: true,
    var classe = records[i];
    classe.ClasseId = classe.ClasseId;
    classe.Descricao = classe.Descricao;
    data.push(classe);
    return data;
    //Source Adpater do Fase
    var faseSource =
    { name: ‘FaseId’ },
    url: “/Cadastro/P100DFase/Lista”,
    async: false
    var faseAdapter = new $.jqx.dataAdapter(faseSource, {
    autoBind: true,
    var fase = records[i];
    fase.FaseId = fase.FaseId;
    fase.Descricao = fase.Descricao;
    data.push(fase);
    return data;
    //Source Adpater do Status
    var statusSource =
    { name: ‘P100D_StatusId’ },
    url: “/Cadastro/P100DStatus/Lista”,
    async: false
    var statusAdapter = new $.jqx.dataAdapter(statusSource, {
    autoBind: true,
    var status = records[i];
    status.FaseId = status.FaseId;
    status.Descricao = status.Descricao;
    data.push(status);
    return data;
    //EndPoint
    type: “GET”,
    datafields:
    { name: ‘NomeProjeto’, type: ‘string’ },
    { name: ‘ResponsavelDesc’, map: ‘Responsavel>Nome’, value: ‘ResponsavelId’, values: { source: responsavelAdapter.records, value: ‘ResponsavelId’, name: ‘Nome’ } },
    { name: ‘ResponsavelId’, map: ‘Responsavel>UsuarioId’ },
    { name: ‘SponsorDesc’, map: ‘Sponsor>Nome’, value: ‘SponsorId’, values: { source: sponsorAdapter.records, value: ‘SponsorId’, name: ‘Nome’ } },
    { name: ‘SponsorId’, map: ‘Sponsor>SponsorId’ },
    { name: ‘RecursoDesc’, map: ‘Recurso>Nome’, value: ‘UsuarioId’, values: { source: recursoAdapter.records, value: ‘UsuarioId’, name: ‘Nome’ } },
    { name: ‘UsuarioId’, map: ‘Recurso>UsuarioId’ },
    { name: ‘FaseDesc’, map: ‘Fase>Descricao’, value: ‘FaseId’, values: { source: faseAdapter.records, value: ‘FaseId’, name: ‘Descricao’ } },
    { name: ‘FaseId’, map: ‘Fase>FaseId’ },
    { name: ‘ClasseDesc’, map: ‘Classe>Descricao’, value: ‘ClasseId’, values: { source: classeAdapter.records, value: ‘ClasseId’, name: ‘Descricao’ } },
    { name: ‘ClasseId’, map: ‘Classe>ClasseId’ },
    { name: ‘DataInicio’, type: ‘date’ },
    { name: ‘DataFim’, type: ‘date’ },
    { name: ‘Duracao’, type: ‘number’ },
    { name: ‘Beneficios’, type: ‘string’ }
    url: url,
    var start = new Date().getTime();
    var data = “add=true&” + $.param(rowdata);
    //alert(rowdata);
    $(“div.footer_content”).html(‘  <i class=”fa fa-pencil-square-o”></i> – Iniciando a execução da edição…Aguarde!’);
    dataType: ‘json’,
    type: ‘POST’,
    url: ‘/P100D/Solicitacao/Novo’,
    cache: false,
    data: data,
    //alert(rowdata);
    jQuery(‘div.footer-status’).css(‘display’, ‘inline’);
    var end = new Date().getTime();
    var time = (end – start) / 1000;
    $(“div.footer_content”).html(‘  <i class=”fa fa-thumbs-o-up”></i> – Dados editados com sucesso em ‘ + time + ‘ ms!’);
    jQuery(‘div.footer-status’).css(‘display’, ‘none’);
    setTimeout(function () {
    $(“div.footer_content”).html(“”);
    }, 5000);
    commit(true);
    //dataAdapter.dataBind();
    //$(“.P100D-Solicitacao”).jqxGrid(‘updatebounddata’);
    $(“div.footer_content”).html(‘  <i class=”fa fa-thumbs-o-down”></i> – <b>ATENÇÃO!!!</b> Ocorreu um erro na sua edição.’);
    commit(false);
    var data = “update=true&” + $.param(rowdata);
    dataType: ‘json’,
    type: ‘POST’,
    url: ‘/P100D/Solicitacao/Editar’,
    cache: false,
    data: data,
    }, 5000);
    commit(true);
    commit(false);
    var data = “delete=true&” + $.param(rowdata);
    dataType: ‘json’,
    type: ‘GET’,
    url: ‘/P100D/Solicitacao/Excluir/’ + rowid,
    data: data,
    $(“#excluirRegistroGrid”).modal(‘hide’);
    commit(false);
    //Marca toda linha que foi editada
    var cellclass = function (row, columnfield, value) {
    if (value < 0) {
    return ‘red’;
    //} else if (value >= 20 && value < 50) {
    //return ‘yellow’;
    } else return “”; // ‘green’;
    width: ‘100%’,
    height: ‘100%’,
    everpresentrowactions: “add reset”,
    //everpresentrowactions: “add remove reset”,//update
    pagesize: 30,
    autoheight: false,
    altrows: true,
    theme: ‘office’,
    enablehover: true,
    groupable: false,
    localization: {
    //{ text: ‘SolicitacaoId’, datafield: ‘SolicitacaoId’ },
    //Nome Projeto
    text: ‘Nome da Demanda / Projeto’,
    columntype: ‘textbox’,
    datafield: ‘NomeProjeto’,
    width: 280,
    minLength: 1,
    maxLength: 50,
    //validation: function (cell, value) {
    // if (value == value.empty) {
    // return { result: false, message: “O Nome do Projeto é obrigatório.” };
    // return true;
    ////Responsável
    // text: ‘Responsável’,
    // align: ‘center’,
    // width: 200,
    // datafield: ‘ResponsavelId’,
    // displayfield: ‘ResponsavelDesc’,
    // columntype: ‘dropdownlist’,
    // createEverPresentRowWidget: function (datafield, htmlElement, popup, addCallback) {
    // var inputTag = $(“<div style=’border: none;’></div>”).appendTo(htmlElement);
    // inputTag.jqxDropDownList({
    // popupZIndex: 99999999,
    // placeHolder: “Informe um Responsável: “,
    // source: responsavelAdapter,
    // displayMember: ‘Nome’,
    // valueMember: ‘ResponsavelId’,
    // width: ‘100%’,
    // height: 30,
    // theme: ‘office’
    // return inputTag;
    // initEverPresentRowWidget: function (datafield, htmlElement) { },
    // getEverPresentRowWidgetValue: function (datafield, htmlElement, validate) { var value = htmlElement.val(); return value; },
    // resetEverPresentRowWidgetValue: function (datafield, htmlElement) { htmlElement.val(null); },
    // createeditor: function (row, value, editor) {
    // editor.jqxDropDownList({
    // promptText: “Informe um Responsável”
    //Fase
    text: ‘Fase’,
    align: ‘center’,
    width: 200,
    datafield: ‘FaseId’,
    displayfield: ‘FaseDesc’,
    placeHolder: “Informe uma Fase: “,
    source: faseAdapter,
    displayMember: ‘Descricao’,
    valueMember: ‘FaseId’,
    width: ‘100%’,
    height: 30,
    theme: ‘office’
    return inputTag;
    promptText: “Informe uma Fase”
    //Classe
    text: ‘Classe’,
    align: ‘center’,
    width: 200,
    datafield: ‘ClasseId’,
    displayfield: ‘ClasseDesc’,
    placeHolder: “Informe uma Classe: “,
    source: classeAdapter,
    valueMember: ‘ClasseId’,
    width: ‘100%’,
    height: 30,
    theme: ‘office’
    return inputTag;
    promptText: “Informe uma Classe”
    initeditor: function (row, value, editor) { },
    geteditorvalue: function (row, value, editor) { return editor.val(); }
    /* — ABERTURA CALENDÁRIO P100D —
    — 1º TRI —
    01/01 – 10/04
    — 2º TRI —
    01/04 – 10/07
    — 3º TRI —
    01/07 – 10/10
    — 4º TRI —
    01/10 – 10/01
    //Data Ínicio
    text: ‘Data Ínicio’, datafield: ‘DataInicio’, width: 110, align: ‘center’, cellsalign: ‘center’, cellsformat: ‘d’,
    columntype: ‘datetimeinput’,
    var dataMesCorrente = new Date().getMonth();
    //var minyear;
    //var minmonth;
    //var minday;
    //var maxday;
    //var maxmonth;
    //var maxyear;
    if (dataMesCorrente == 0) {
    var minyear = new Date().getFullYear();
    var minmonth = 0;
    var minday = 11;
    var maxmonth = 3;
    var maxday = 10;
    var maxyear = new Date().getFullYear();
    if (dataMesCorrente == 3) {
    var minmonth = 3;
    var minday = 11;
    var maxmonth = 6;
    var maxday = 10;
    if (dataMesCorrente == 6) {
    var minmonth = 6;
    var minday = 11;
    var maxmonth = 9;
    var maxday = 10;
    if (dataMesCorrente == 9) {
    var minmonth = 9;
    var minday = 11;
    var maxmonth = 11;
    var maxday = 10;
    //var minyear = new Date().getFullYear();
    //var minmonth = 6;
    //var minday = 1;
    //var maxmonth = 9;
    //var maxday = 10;
    //var maxyear = new Date().getFullYear();
    inputTag.jqxDateTimeInput({
    min: new Date(minyear, minmonth, minday),
    max: new Date(maxyear, maxmonth, maxday),
    value: null,//”2000, 1, 1″,
    placeHolder: “Data Ínicio: “,
    width: ‘100%’, height: 30, theme: ‘office’, culture: “pt-BR”
    $(document).on(‘keydown.date’, function (event) {
    if (event.keyCode == 13) {
    if (event.target === inputTag[0]) {
    addCallback();
    else if ($(event.target).ischildof(inputTag)) {
    addCallback();
    return inputTag;
    //createeditor: function (row, value, editor) { },
    //initeditor: function (row, value, editor) { },
    //geteditorvalue: function (row, value, editor) {
    // // return the editor’s value.
    // return editor.val();
    //Data Fim
    text: ‘Data Fim’, datafield: ‘DataFim’, width: 110, align: ‘center’, cellsalign: ‘center’, cellsformat: ‘d’,
    //var minyear;
    //var minmonth;
    //var minday;
    //var maxday;
    //var maxmonth;
    //var maxyear;
    var minmonth = 0;
    var minday = 11;
    var maxmonth = 3;
    var maxday = 10;
    var minmonth = 3;
    var minday = 11;
    var maxmonth = 6;
    var maxday = 10;
    var minmonth = 6;
    var minday = 11;
    var maxmonth = 9;
    var maxday = 10;
    var minmonth = 9;
    var minday = 11;
    var maxmonth = 11;
    var maxday = 10;
    value: null,
    placeHolder: “Data Fim: “,
    width: ‘100%’,
    height: 30,
    theme: ‘office’,
    culture: “pt-BR”
    addCallback();
    addCallback();
    return inputTag;
    return value;
    //Duração
    text: ‘Duração’,
    datafield: ‘Duracao’,
    width: 150,
    editable: false,
    var inputTag = $(“<div style=’border: none; background-color:#FFF !Important;’></div>”).appendTo(htmlElement);
    return inputTag;
    return value;
    //Sponsor
    text: ‘Sponsor’,
    align: ‘center’,
    width: 200,
    datafield: ‘SponsorId’,
    displayfield: ‘SponsorDesc’,
    placeHolder: “Informe um Sponsor: “,
    source: sponsorAdapter,
    valueMember: ‘SponsorId’,
    width: ‘100%’,
    height: 30,
    theme: ‘office’
    return inputTag;
    source: sponsorAdapter, displayMember: ‘Nome’, valueMember: ‘SponsorId’, promptText: “Informe um Sponsor”
    //Recurso
    text: ‘Recursos’, cellclassname: cellclass, // (Áreas Impactadas) – (min. 1; máx. 5)
    datafield: ‘UsuarioId’,
    displayfield: ‘Recurso’,
    width: 230,
    checkboxes: false,
    placeHolder: “Informe os Recursos: “,
    source: recursoAdapter,
    valueMember: ‘UsuarioId’,
    width: ‘100%’,
    height: 30,
    theme: ‘office’
    return inputTag;
    return value;
    checkboxes: false, source: recursoAdapter, displayMember: ‘Nome’, valueMember: ‘UsuarioId’
    //// set the editor’s current value. The callback is called each time the editor is displayed.
    //var items = editor.jqxDropDownList(‘getItems’);
    //editor.jqxDropDownList(‘uncheckAll’);
    //var values = cellvalue.split(/,\s*/);
    //for (var j = 0; j < values.length; j++) {
    // for (var i = 0; i < items.length; i++) {
    // if (items[i].label === values[j]) {
    // editor.jqxDropDownList(‘checkIndex’, i);
    //Representantes
    width: 230,
    checkboxes: false,
    width: ‘100%’,
    height: 30,
    theme: ‘office’
    return inputTag;
    checkboxes: false,
    //selectedIndex: 1,
    height: 30,
    theme: ‘office’,
    //Benefícios
    text: ”,
    datafield: ‘Beneficios’,
    columngroup: ‘BENEFICIO’,
    width: 200,
    editable: false,
    return inputTag;
    return value;
    createeditor: function (row, value, editor, htmlElement) { },
    //Button Editar Beneficio
    text: ”,
    datafield: ‘Edit’,
    width: 100,
    columntype: ‘button’,
    cellsrenderer: function () {
    return “Editar”;
    return inputTag;
    return value;
    buttonclick: function (row) {
    editrow = row;
    //var offset = $(“.P100D-Solicitacao”).offset();
    $(“#popupWindow”).jqxWindow({
    showCollapseButton: true, maxHeight: 400, maxWidth: 700, minHeight: 200, minWidth: 200, height: 300, width: 500
    var dataRecord = $(“.P100D-Solicitacao”).jqxGrid(‘getrowdata’, editrow);
    $(“#Beneficios”).val(dataRecord.Beneficios);
    // show the popup window.
    $(“#popupWindow”).jqxWindow(‘open’);
    datafield: ‘addButtonColumn’,
    text:”,
    width: 50
    columngroups: [
    { text: ‘Benefícios’, align: ‘center’, name: ‘BENEFICIO’ }
    width: 250, resizable: true, isModal: true, theme: ‘office’, autoOpen: false, cancelButton: $(“#Cancel”), modalOpacity: 0.01
    $(“#popupWindow”).on(‘open’, function () {
    $(“#Beneficios”).jqxInput(‘selectAll’);
    $(“#Cancel”).jqxButton({ theme: ‘office’ });
    $(“#Save”).jqxButton({ theme: ‘office’ });
    // update the edited row when the user clicks the ‘Save’ button.
    if (editrow >= 0) {
    var row = {
    Beneficios: $(“#Beneficios”).val()
    var rowID = $(‘.P100D-Solicitacao’).jqxGrid(‘getrowid’, editrow);
    $(‘.P100D-Solicitacao’).jqxGrid(‘updaterow’, rowID, row);
    //Event Bind
    $(“.P100D-Solicitacao”).bind(‘bindingcomplete’, function () {
    $(“.P100D-Solicitacao”).bind(‘cellbeginedit’, function (event) {
    var args = event.args;
    var columnDataField = args.datafield;
    var rowIndex = args.rowindex;
    var cellValue = args.value;
    $(“.P100D-Solicitacao”).bind(‘cellendedit’, function (event) {
    var oldValue = args.oldvalue;
    $(“.P100D-Solicitacao”).jqxGrid(‘sortby’, ‘NomeProjeto’, ‘asc’);
    //Cria um contexto de menu para a Grid
    var contextMenu = $(“#Menu”).jqxMenu({ width: 200, height: 35, autoOpenPopup: false, mode: ‘popup’ });
    //Desabilita o contexto do menu do Windows na Grid
    $(“.P100D-Solicitacao”).on(‘contextmenu’, function () {
    return false;
    // handle context menu clicks.
    $(“#Menu”).on(‘itemclick’, function (event) {
    $(“#excluirRegistroGrid”).modal(‘show’);
    $(“.P100D-Solicitacao”).on(‘rowclick’, function (event) {
    if (event.args.rightclick) {
    $(“.P100D-Solicitacao”).jqxGrid(‘selectrow’, event.args.rowindex);
    contextMenu.jqxMenu(‘open’, parseInt(event.args.originalEvent.clientX) + 5 + scrollLeft, parseInt(event.args.originalEvent.clientY) + 5 + scrollTop);
    return false;
    $(“#excluirRegistro”).click(function () {
    var rowindex = $(“.P100D-Solicitacao”).jqxGrid(‘getselectedrowindex’);
    var rowid = $(“.P100D-Solicitacao”).jqxGrid(‘getrowid’, rowindex);
    $(“.P100D-Solicitacao”).jqxGrid(‘deleterow’, rowid);
    //Limitar escrita Beneficios MaxChar = ‘500’
    function countChar(val) {
    var len = val.value.length;
    if (len >= 500) {
    val.value = val.value.substring(0, 500);
    } else {
    $(‘#charNum’).text(500 – len);
    function toolBarJQWidgets() {
    var localizationobj = {};
    localizationobj.pagergotopagestring = “Página:”;
    localizationobj.pagershowrowsstring = “Mostrando:”;
    localizationobj.pagerrangestring = ” de “;
    localizationobj.pagernextbuttonstring = “Próximo”;
    localizationobj.pagerpreviousbuttonstring = “Anterior”;
    localizationobj.sortascendingstring = “Classificar do Menor para o Maior”;
    localizationobj.sortdescendingstring = “Classificar do Maior para o Menor”;
    localizationobj.sortremovestring = “Limpar Classificação”;
    localizationobj.groupsheaderstring = “Arraste a coluna e solte-o aqui para grupo por essa coluna”;
    localizationobj.groupbystring = “Grupo por esta coluna”;
    localizationobj.groupremovestring = “Remover de grupos”;
    localizationobj.firstDay = 1;
    localizationobj.percentsymbol = “%”;
    localizationobj.emptydatastring = “Não existem Lançamentos cadastrados”;
    //localizationobj.currencysymbol = “R$”;
    localizationobj.currencysymbolposition = “before”;
    localizationobj.decimalseparator = “,”;
    localizationobj.thousandsseparator = “.”;
    localizationobj.filterclearstring = “Limpar”;
    localizationobj.filterstring = “Filtrar”;
    localizationobj.filterselectallstring = “(Selecione Todos)”,
    localizationobj.filtershowrowstring = “Mostrar linhas onde”;
    localizationobj.filterorconditionstring = “ou”;
    localizationobj.filterandconditionstring = “e”;
    localizationobj.filterchoosestring = “Por Favor Escolha:”;
    localizationobj.filterstringcomparisonoperators = [
    ‘vazio’, ‘não está vazio’, ‘conter (caso partida) ‘,
    ‘não contém’, ‘não contém (caso partida)’, ‘começa com’, ‘começa com (caso partida)’,
    ‘termina com’, ‘termina com (caso partida)’, ‘igual’, ‘(caso partida) igual’, ‘nulo’, ‘não nulo’
    localizationobj.filternumericcomparisonoperators = [‘igual’, ‘não é igual’, ‘menos do que’, ‘menor ou igual’, ‘maior do que’, ‘maior ou Igual’, ‘nulo’, ‘não nulo’];
    localizationobj.filterdatecomparisonoperators = [‘igual’, ‘não é igual’, ‘menos do que’, ‘menor ou igual’, ‘maior do que’, ‘maior ou Igual’, ‘nulo’, ‘não nulo’];
    localizationobj.filterbooleancomparisonoperators = [‘igual’, ‘não é igual’];
    localizationobj.validationstring = “Valor inserido não é válido”;
    localizationobj.emptydatastring = “Nenhuma informação”;
    localizationobj.filterselectstring = “Selecionar Filtros”;
    localizationobj.loadtext = “Carregando …”;
    localizationobj.clearstring = “Limpar”;
    localizationobj.todaystring = “Hoje”;
    var days = {
    // full day names
    names: [“Domingo”, “Segunda”, “Terça”, “Quarta”, “Quinta”, “Sexta”, “Sabado”],
    // abbreviated day names
    namesAbbr: [“Dom”, “Seg”, “Ter”, “Qua”, “Qui”, “Sex”, “Sab”],
    // shortest day names
    namesShort: [“D”, “S”, “T”, “Q”, “Q”, “S”, “S”]
    localizationobj.days = days;
    var months = {
    // full month names (13 months for lunar calendards — 13th month should be “” if not lunar)
    names: [“Janeiro”, “Fevereiro”, “Março”, “Abril”, “Maio”, “Junho”, “Julho”, “Agosto”, “Setembro”, “Outubro”, “Novembro”, “Dezembro”, “”],
    // abbreviated month names
    namesAbbr: [“Jan”, “Fev”, “Mar”, “Abr”, “Mai”, “Jun”, “Jul”, “Ago”, “Set”, “Out”, “Nov”, “Dez”, “”]
    localizationobj.months = months;
    var patterns = {
    d: “dd/MM/yyyy”,
    D: “dddd, d. MMMM yyyy”,
    t: “HH:mm”,
    T: “HH:mm:ss”,
    f: “dddd, d. MMMM yyyy HH:mm”,
    F: “dddd, d. MMMM yyyy HH:mm:ss”,
    M: “dd MMMM”,
    Y: “MMMM yyyy”
    localizationobj.patterns = patterns;
    //localizationobj.months = months;
    var allEra = {
    eras: [{ “name”: “A.D.”, “start”: null, “offset”: -543 }]
    localizationobj.eras = allEra;
    // apply localization.
    return localizationobj;
    Hi paulo.junior,
    As I said in my previous post, we would need some sample data from both sources to be able to test your first example and determine why the issue occurs. Your second code sample is too extensive for us to review in detail.
    paulo.junior
    Hello Dimitar,
      Thanks for the help, we can solve the Combobox loading issue with Checkbox. And now that the items are selected but in the view of the Grid, the combo is only coming with a checked item. How can I display all selected on the line, separating with “,”.
    ———————Solution———————————–
    var values = $(‘.P100D-Solicitacao’).jqxGrid(‘getrowdata’, row).RepresentantesId; //Solution
    if (items[i].value === values[j]) {
    Hi paulo.junior,
    I think what you require can be seen in the demo Custom Column Editor (column “Products”).
